Is anyone else having problems with changing their “Auto lock” setting from the ST app? I’ve managed to turn off Auto Lock from the app recently and the lock has stopped unlocking. That was what I wanted for a week when we had workmen coming in and out, but the issue is now when I try to turn it back on.
First, the UI shows the state of Auto Lock as ON rather than OFF. I can try toggling the state to OFF and it seems to work, but then toggling back to ON, it just spins and gives a network error. If I refresh the screen, it once again says Auto Lock is ON (when it is still OFF). Looking at the CLI logs, it seems to only be sending OFF commands, but not ON.
2024-03-07T01:52:21.655499745+00:00 TRACE Z-Wave Lock PH Received event with handler capability
2024-03-07T01:52:21.675936958+00:00 TRACE Z-Wave Lock PH Z-Wave command(6f9ec7f6) queued for radio transmission: CC:Configuration, CID:0x04
2024-03-07T01:52:21.681230604+00:00 INFO Z-Wave Lock PH <ZwaveDevice: 4b1015f2-7483-44b5-a899-f05602334881 [2F] (Front Door Lock)> received command: {"args":{},"capability":"platinummassive43262.autoLock","command":"off","component":"settings","positional_args":{}}
2024-03-07T01:52:21.716574600+00:00 TRACE Z-Wave Lock PH Found CapabilityCommandDispatcher handler in zwave_lock -> Schlage Lock -> Schlage BE469
2024-03-07T01:52:21.721032495+00:00 INFO Z-Wave Lock PH <ZwaveDevice: 4b1015f2-7483-44b5-a899-f05602334881 [2F] (Front Door Lock)> sending Z-Wave command: {args={configuration_value=0, default=false, parameter_number=15, size=1}, cmd_class="CONFIGURATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x0F\x01\x00", src_channel=0, version=1}
2024-03-07T01:52:21.725927941+00:00 DEBUG Z-Wave Lock PH Front Door Lock device thread event handled
2024-03-07T01:52:23.201436994+00:00 TRACE Z-Wave Lock PH Z-Wave command(6f9ec7f6) transmit status: TRANSMIT_COMPLETE_OK
2024-03-07T01:52:28.365032170+00:00 TRACE Z-Wave Lock PH Received event with handler capability
2024-03-07T01:52:28.387794212+00:00 TRACE Z-Wave Lock PH Z-Wave command(f6b3f7cb) queued for radio transmission: CC:Configuration, CID:0x04
2024-03-07T01:52:28.390465214+00:00 INFO Z-Wave Lock PH <ZwaveDevice: 4b1015f2-7483-44b5-a899-f05602334881 [2F] (Front Door Lock)> received command: {"args":{},"capability":"platinummassive43262.autoLock","command":"off","component":"settings","positional_args":{}}
2024-03-07T01:52:28.405487721+00:00 TRACE Z-Wave Lock PH Found CapabilityCommandDispatcher handler in zwave_lock -> Schlage Lock -> Schlage BE469
2024-03-07T01:52:28.409991972+00:00 INFO Z-Wave Lock PH <ZwaveDevice: 4b1015f2-7483-44b5-a899-f05602334881 [2F] (Front Door Lock)> sending Z-Wave command: {args={configuration_value=0, default=false, parameter_number=15, size=1}, cmd_class="CONFIGURATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x0F\x01\x00", src_channel=0, version=1}
2024-03-07T01:52:28.415355653+00:00 DEBUG Z-Wave Lock PH Front Door Lock device thread event handled
2024-03-07T01:52:29.881569727+00:00 TRACE Z-Wave Lock PH Z-Wave command(f6b3f7cb) transmit status: TRANSMIT_COMPLETE_OK
2024-03-07T01:53:29.990420488+00:00 TRACE Z-Wave Lock PH Received event with handler capability
2024-03-07T01:53:30.005650432+00:00 TRACE Z-Wave Lock PH Z-Wave command(e13a8f20) queued for radio transmission: CC:Configuration, CID:0x04
2024-03-07T01:53:30.008302424+00:00 INFO Z-Wave Lock PH <ZwaveDevice: 4b1015f2-7483-44b5-a899-f05602334881 [2F] (Front Door Lock)> received command: {"args":{},"capability":"platinummassive43262.autoLock","command":"off","component":"settings","positional_args":{}}
2024-03-07T01:53:30.020798002+00:00 TRACE Z-Wave Lock PH Found CapabilityCommandDispatcher handler in zwave_lock -> Schlage Lock -> Schlage BE469
2024-03-07T01:53:30.035456328+00:00 INFO Z-Wave Lock PH <ZwaveDevice: 4b1015f2-7483-44b5-a899-f05602334881 [2F] (Front Door Lock)> sending Z-Wave command: {args={configuration_value=0, default=false, parameter_number=15, size=1}, cmd_class="CONFIGURATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x0F\x01\x00", src_channel=0, version=1}
2024-03-07T01:53:30.041063797+00:00 DEBUG Z-Wave Lock PH Front Door Lock device thread event handled
2024-03-07T01:53:31.501696749+00:00 TRACE Z-Wave Lock PH Z-Wave command(e13a8f20) transmit status: TRANSMIT_COMPLETE_OK
2024-03-07T01:53:59.925509563+00:00 TRACE Z-Wave Lock PH Received event with handler capability
2024-03-07T01:53:59.953930099+00:00 TRACE Z-Wave Lock PH Z-Wave command(8ba1891d) queued for radio transmission: CC:Configuration, CID:0x04
2024-03-07T01:53:59.956583759+00:00 INFO Z-Wave Lock PH <ZwaveDevice: 4b1015f2-7483-44b5-a899-f05602334881 [2F] (Front Door Lock)> received command: {"args":{},"capability":"platinummassive43262.autoLock","command":"off","component":"settings","positional_args":{}}
2024-03-07T01:53:59.961860396+00:00 TRACE Z-Wave Lock PH Found CapabilityCommandDispatcher handler in zwave_lock -> Schlage Lock -> Schlage BE469
2024-03-07T01:54:00.023703635+00:00 INFO Z-Wave Lock PH <ZwaveDevice: 4b1015f2-7483-44b5-a899-f05602334881 [2F] (Front Door Lock)> sending Z-Wave command: {args={configuration_value=0, default=false, parameter_number=15, size=1}, cmd_class="CONFIGURATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x0F\x01\x00", src_channel=0, version=1}
2024-03-07T01:54:00.035192377+00:00 DEBUG Z-Wave Lock PH Front Door Lock device thread event handled
2024-03-07T01:54:01.381732644+00:00 TRACE Z-Wave Lock PH Z-Wave command(8ba1891d) transmit status: TRANSMIT_COMPLETE_OK
