Preview | SmartThings-managed Edge Device Drivers
Something like dynamic profile/metadata support? I believe this kind of model-based preference can be handled via subdrivers.
If you have a specific use case for this inquiry, share it below to see if we can figure something out = )
My driver needs to be configured with an IP address of a physical device. The device doesn’t support any kind of discovery, and I can’t modify it. The device is actually a β€˜conduit’ to multiple devices β€˜behind’ it, so yes, perhaps subdrivers is an option, although I’ve found it much easier so far not to go that route. I may need to rethink things…
3 posts were split to a new topic: [ST Edge] - Driver Lifecycle Inquiries
I’m not sure if this will be helpful to anyone else, but I’ve been saving the following as a batch file for each of my drivers so that I I can double click it and execute all those commands…
@echo off
set driverPath=C:\Users\...
set driverId=
set channelId=
set hubId=
cd c:\smartthings
echo Packaging Driver...
smartthings edge:drivers:package "%driverPath%"
echo:
echo Publishing Driver to Channel...
smartthings edge:drivers:publish %driverId% --channel %channelId%
echo:
echo Installing Driver...
smartthings edge:drivers:install %driverId% --channel %channelId% --hub %hubId%
echo:
pause
This is the one I use for logging:
@echo off
set driverId=
set hubAddress=192.168.x.x
cd c:\smartthings
smartthings edge:drivers:logcat %driverId% --hub-address=%hubAddress%
echo:
pause
Kevin - Can I get access to your new channel? I’d like to try out a few more devices!
I’ve sent the invite, but I currently only have drivers posted for the ZSE41 and ZSE42
Thank you sir!
2 posts were split to a new topic: [ST Edge] Issues with channels in iOS
Thanks Kevin, thanks just the biscuitπŸ‘
2 posts were split to a new topic: [ST Edge] - Local HTTP Requests
Thanks, I think…:confused:
Kevin , can I get access to your channel, please.
I just sent you an invite, but I only have drivers posted for the Zooz ZSE41 and ZSE42.
I have modified an edge driver following the tutorial of @jody.albritton and everything has gone well up to the edge: channels: enroll.
C: \ smartthings>. \ Smartthings edge: channels: enroll
β”Œβ”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€ ───┐
β”‚ # β”‚ Name β”‚ Channel Id β”‚
β”œβ”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€ ────
β”‚ 1 β”‚ Mariano β”‚ aa9ae2b2-38c3-4666-a395-xxxxxxxxxx β”‚
└───┴─────────┴─────────────────────────────────── β”€β”€β”€β”˜
? Select a channel. 1
β”Œβ”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”
β”‚ # β”‚ Label β”‚ Name β”‚ Device Id β”‚
β”œβ”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€
β”‚ 1 β”‚ SmartThings Hub β”‚ SmartThings v3 Hub β”‚ d6c3122b-1c8b-423c-add4-xxxxxxxxxxx β”‚
β””β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”˜
? Select a hub. 1
Error: Request failed with status code 403: {β€œrequestId”: β€œ1ACCE928-FFFF-410E-82F4-42D5C003781F”, β€œerror”: {β€œcode”: β€œForbiddenError”, β€œmessage”: β€œForbidden”, β€œdetails” : }}
  • I try to answer with the Hub id, that he shows me and gives the same error
I have the PAT, with all the permissions, in the config.yaml. If I delete it, nothing works, therefore it seems that it uses the PAT correctly.
My Hub is enrolled in Beta driver.
I have rebooted the Hub.
I don’t know what’s going on, any recommendations?
@nayelyz can you help regarding this?
If I ask him to show me all my edge drivers, he shows me drivers that I have never made or created, in fact only the zigbee smoke sensor heiman is the one that I have uploaded.
The other 3 drivers are groovy DTH drivers that I made a long time ago and deleted them from the IDE
C:\smartthings> .\smartthings edge:drivers
β”Œβ”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”
β”‚ # β”‚ Driver Id β”‚ Name β”‚ Version β”‚ Package Key β”‚
β”œβ”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€
β”‚ 1 β”‚ 7c13984b-8bb8-4c7e-a0ce-cf237526e9da β”‚ smartthings/SmartSense Moisture Sensor+TimeRep+TempChangeRep β”‚ 2021-03-03T19:58:59.427973 β”‚ β”‚
β”‚ 2 β”‚ 51209c7d-ed9c-410b-8f78-caf7f2b06e63 β”‚ smartthings/SmartSense Motion Sensor-Prueba β”‚ 2021-01-07T12:25:11.490997 β”‚ β”‚
β”‚ 3 β”‚ c674c3fa-9a55-45b8-8715-4e8455fe3b4e β”‚ smartthings/SmartSense Multi Sensor-Prueba β”‚ 2021-01-07T10:54:28.829639 β”‚ β”‚
β”‚ 4 β”‚ b397d7a3-fb49-463e-8e96-6aa971ca62b3 β”‚ smartthings/ZigBee Valve β”‚ 2020-12-07T11:22:35.068884 β”‚ β”‚
β”‚ 5 β”‚ a2f7ec78-14c8-492d-9965-xxxxxxx β”‚ Zigbee Smoke Detector Heiman β”‚ 2021-08-26T23:10:09.624676 β”‚ zigbee-smoke-detector-heiman β”‚
β””β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”˜
Tag him here so that you can let him know.
Yes, I had that. Unfortunately I got rid of them before the account could be inspected.
You can try disabling your current config.yaml with the PAT (changing the file name will do the work) and use the default OAuth flow to get the corresponding permissions.
Once you disable the file, a web browser page will open automatically when you execute a CLI command and it will ask you to authorize the access.
More info here:
BTW, I already reported this to Caleb, I’ll let you know the feedback.
Thank you, I will try it as soon as I can and inform you
