Not sure if the latest firmware has caused an issue, but presence detection upon returning home after being away for 30 minutes or more has stopped working as expected.
I have a routine that basically says when i return home after being away for 30+ minutes, turn on a virtual presence sensor, then turn it off after 10 minutes.
What’s actually happening is that it detects I’ve returned, turns on the presence sensor, then immediately turns it off.
I know other things are not working as they should be, so another one to add to the list?
It’s ironic that you created this post as I was thinking of asking for help on solving the presence sensing problems I’ve been having.
ST presence sensing has never reliably worked for me either. I have tried everything that I can think of to fix it - adjusting geofence radius, deleting and recreating routines that depend on presence, toggling the presence routine on/off - but nothing has helped. Literally every other app that I use for presence detection automations (Google Home, Nest, MacroDroid) all work flawlessly so I have no idea what the problem is with the ST app.
I gave up on ST app presence sensing long ago. Was using Life360 until January when Groovy apps were shut down. Since then I’ve been using Alexa app location to trigger virtual presence sensors in ST. Works very reliably.
Identified - The issue has been identified and seems to be affecting users due to “Daylight Savings Time” being on for US region. Expectation is that as the day turns to tomorrow, the issues should go away.
Mar 12, 2023 - 23:29 UTC
I think it is most time based routines not just Smartlighting.
I’m not using any part of the Amazon Alexa ecosystem so that isn’t an option for me. What I like about MacroDroid is that it gives me the ability to set the GPS location polling frequency - which works great. At first I thought my trouble with ST presence sensing was being caused by the fact that I use ZeroTier One to connect to my Pi-hole for DNS ad and tracker blocking while on the mobile network but that possibility was eliminated because the other apps which rely on geolocation for automations work fine. It’s been bothering me for a while that I haven’t been able to figure out why the ST app is so bad at geolocation.
I see there was a solution but the Improved Mobile Presence (smartapp?) is now obsolete and hasn’t yet been updated to work with Edge.
I have several different types of presence sensing methods on Android.
Tasker using a Geofences plugin called AutoLocation.
Stock ST location that sets a VR presence Sensor. This has a switch capability that allows you to toggle, on/off / present/not present
(If you have a Schlage Smart lock you can use a custom drive that supplies the lock codeName you can use that as a backup to set presence)
Tasker to intercept life360 notifications using a plugin called AutoNotification. This in turn sends a rest API command to toggle the a VR presence sensor.
Us GH home and away routines to toggle a master VR presence sensor (anyone home / everyone away)
I also have a ST routine that sets the presence based on who unlocks the front door.
As you can see Tasker has a lot to do with it but you can definitely do the last one in sharptools or ST. I will be happy to help with any questions you have.
Hitting two birds with one stone in this thread; I’m giving up on ST presence sensing and trying the virtual switch approach that’s triggered by a Google Home app Away routine. Should’ve done this long ago. Thanks.
