Which hub do you have? The name of the hub is the same name you see in IDE
No need to uninstall app
You could try deleting and reinstalling the app, but it will mess up the sorting order of your rooms and devices.
I have older Hub v2 US. I named my hub generic âHome Hubâ but nowhere to be found in ST app
It should look like this
Does android add System or did you rename your hub to System Home Hub?
Just curious
System is the room where I keep generic devices
Yea, I found my hub that was lost in a black hole somehow. I had to click on the 3 dots â choose âBring devices from other roomsâ â I can now see the previously missing hub listed in that long list of devices so can now select itâs radio button and is displayed in my âAllâ list.
iOS does not add the room name on tiles.
Either does Android, unless it is on your favorites page, where I took the screen shot. I have it there because of all the driver juggling I have done over the past 18 months.
Ah yes :slight_smile
I excluded the the zcombo detector 3 times successfully from my hub but it still doesnât want to pair for some reason. Trying to re-add via scan and by brand made no difference so giving up after a dozen tries so will have to retry again this weekend. Hopefully my other two working units donât drop off like this 3rd unit.
I have 3 of the zcombo all paired with no issues. Using the stock Edge Zwave Smoke Alarm driver.
Do you mind telling me what the exclusion process is for these devices? Iâm planning on manually converting them to an edge driver this weekend.
https://support.firstalert.com/sfc/servlet.shepherd/document/download/0693l00000DinTRAAZ
Bottom right corner of the 2nd page.
I need also ZXT-120 as I know switchbot only have on off for smartthings
Not heat or cool or temperature selection
Have you figured out a way to keep the HS-WX300 LED indicators working post Groovy?
Has this happened? Just got a SmartThings hub and Iâm seriously disappointed with the support for Qubino. Seems they just killed Groovy and then then didnât botherâŚ
I have the Utiltec Water Sensor that is the same as the Everspring and it works with STâs stock âZ-Wave Sensorâ Driver. So I would try that driver.
Hello,
I have four of the old Swiidinter cord switches installed and I canât seem to be able to get them to use Edge drivers. They are very basic Z-Wave switches, but are only recognised as DTH devices and there seems to be no way to force the Edge driver.
From the old IDE, the raw description is:
zw:L type:1001 mfr:0166 prod:0100 model:0100 ver:1.82 zwv:3.67 lib:06 cc:25,27,85,72,86
Can that somehow be added? Or can someone tell me how to force Smartthings to use the standard Z-Wave Switch Edge driver instead of the DTH?
Thanks!!
Ask @Mariano_Colmenarejo he may be able to add them to his âZ-Wave Switch and Child Mcâ driver.
