Is anyone working on a driver for the IKEA Vindstyrka air quality sensor?
Still no luck on my end, if I find something I will report it back.
Two previous topics have covered the driver for this device:
SmartThings is not supporting PM2.5 measurement.
all good? Would it be possible to add this device to your driver? It’s a switch to control curtains and blinds.
Hi group
Looking for a compatible driver to my 3A RGBW light strip Zigbee controller, model FB56-ZCW20FB1.2. Manufacturer code is FeeBit RGBW.
It is detected as a Zigbee Switch but I cannot change the light intensity or the color temperature.
I attached the device fingerprint. And yes I tried the MC Zigbee Light driver, it’s not included in it.
Hi @SneakX2018
I take note to do it in the month of August, until then I do not have access to the CLI or a pc
No problem, for now I still have limited control so I think I’ll survive. ![]()
Many thanks
Request for Iris keypad 3405-L edge driver.
Thank you
There is a new Ikea Button called Rodret. Any Idea how to bring it working? I have it in the app, but it just shows up as a “Zigbee thing” not as a button. I could not find a working edge driver.
Manual: https://www.ikea.com/at/de/manuals/rodret-kabelloser-dimmer-schalter-smart-weiss__AA-2386992-1-2.pdf
Good night, @Mariano_Colmenarejo beauty. Could you please check the Zigbee Light Multifuncion MC driver fingerprint on an Aqara device. I bought the AQARA T1 LED strip and it paired with its driver, but I’m managing to partially control the Cold White and Warm White and On and Off using the smartthings app and voice command from Alexa and Google assistants. I’m not able to control the Cores of the ribbon’s RGB either by the Smartthings application or by voice command. I try to change the color through the control in the app and it is stuck and does not change. Could you please check in your driver about the RGB control. Follow the device link on aliexpress and shopee , in addition to the attachment of the device fingerprint.
https://pt.aliexpress.com/item/1005005751145891.html?spm=a2g0o.store_pc_allProduct.8148356.3.51e118f9PwDeCA&pdp_npi=3%40dis!BRL!R%24%20327%2C10!R%24%20245%2C32!!!!!%40210318d116893749450217575e2098!12000034222394195!sh!BR!2106986981
https://shopee.com.br/Aqara-New-T1-Streamer-light-Trabalhar-Com-Apple-Homekit-Seu-Próprio-Motorista-i.640638220.21598653047?sp_atk=ac6dce09-1a96-4644-98f9-a6daae9d95d0&xptdk=ac6dce09-1a96-4644-98f9-a6daae9d95d0
Alright, wait until then.
All 4 Keypads failed today (7/21/23) at Both Houses.
System must have been updated by SmartThings.
I need an Edge Driver for …
Type: Security Keypad
Make: IRIS / CentraLite
Model: 3405-L - 2nd Gen
Alarm Set Keypad has worked for Years, until today.
Small Children, without Cell Phone, can no longer activate or deactivate the House Alarm.
It’s in the works
Thanks.
I think I was using your Device Driver on old IDE.
Looking for an edge driver for Philips Hue motion SML002 without using a Philips hub.
It used to work with a DTH however after a firmware upgrade of the ST hub it shows as a zibee thing and doesn’t work anymore.
Maybe this driver supports SML002
[Edge Driver] Hue Motion Sensor (No Hue Bridge) - Devices & Integrations / Community Created Device Types - SmartThings Community
You have to enroll your hub channel from invitation link
Install the driver on your hub
Put your device in pairing mode
In the App add a new device with the option to search nearby.
If the device is compatible with the driver, it will pair and appear in the room where you have the Hub.
It worked.
Thanks a million
I have also had major keypad failure - also based on the Rboy Enhanced ZigBee Keypad DTH. I need a driver for the Xfinity XHK1-UE.
Can anyone help please…
Could this be added to your Zigbee Lock Mc driver? Just for basic lock functionality?
