Post Requests for Zigbee Edge Drivers Here (community-created)
I have two orvibo door/window sensors which I thought would work with the Zigbee Contact Mc driver but it fails the fingerprint match with a manufacturer code in what looks like chinese.
Suggestions welcomed please!
what are your fingerprints?
@RBoy - its important to know when we might get this driver please. I think I am going to have to replace my keypads with Ring keypads for which there is a driver. I have ordered one to test. But if the driver could come before I make this big expensive change…
Presentation id
bc813f60-efa1-3d89-896d-93ef64cf89c8
Model
75a4bfe8ef9c4350830a25d13e3ab068
Manufacturer Code
欧瑞
I take note to add it in the month of August, until then I do not have access to the CLI or a pc
I’ve got a similar case where the default Edge driver pairs, but neither yours nor the Jasco swithc drivers pairs with it. I need to change the reporting rate. I’ve attached the details:
Sorry, I don’t have any drivers that work with this device, nor that allow configuration settings
Good Afternoon, @Mariano_Colmenarejo please add the fingergrit to the Zigbee buttons driver, the fingerprint of the Aqara Smart Knob H1 wireless to your drivers. It has the functions of single click, double click, click and hold, Rotation and pressed rotation. Below is the print of the fingerprint of this device.
Sorry, this is not as easy as adding the fingerprints to the driver.
This device does not work in a standard way like smarthings buttons
@Mariano_Colmenarejo Got it, surely it must be the clusters are different. Thank you for responding to the request.
@RafaelAntonio2022
Maybe works with @veonua driver
Did you actually find an Edge driver for this?
SOLVED: With the lack of support or any advice (I tried facebook, email and this forum) from Rboy who made the original driver, I was facing the replacement of my 9 ZHK1-UE keypads. Ive realised there is a simple solution - I checked the driver situation online and Ive bought a second hand Hubitat C8 and Im off. So long - and thanks for all the fish…
Hello. Has anyone been successful lately in locating working Edge Drivers for the Comcast XHK keypad? I had them working with the old rboy legacy drivers.
3 posts were merged into an existing topic: Post Requests for LAN Edge Drivers Here (community-created)
@Mariano_Colmenarejo does my information is correct to add the fingerprint to existing driver ?
thanks!
Hi @plboucher
Sorry, I forgot to answer you.
I’ll try to add it in August and see if it works. some functions may not work well, I don’t know what the 000C cluster uses, analog input
Hello, I would use this zigbee keyfob in smartthing:
Linkind ZS130000178
Linkind ZS130000178 control via MQTT | Zigbee2MQTT
Device ID: 05824e6c-b711-4ab4-bd50-cf4acb78d9de
Presentation ID: 0b49a9a6-e730-357d-a9f6-6ad05a24b5c9
This device exist in the driver some time ago
- id: "LUMI/SmokeSensor-N"
    deviceLabel: LUMI Smoke Sensor
    manufacturer: LUMI
    model: lumi.sensor_smoke
    deviceProfileName: smoke-battery
Can anyone help me with a driver for an heiman smart remote button controller? Unfortunately the ones i tried where not working.
