Pairing Aqara vibration sensor is impossible… I can’t do it. Any advice?
I currently have 3 vibration sensors deployed which I Have , in the past, registerd to Smartthings via community written edge drivers and directly to Aqara. The fun part with Matter is every thing is everywhere for me so I have duplicates , a rant for another day,
Anyway, what is the process you are following in tryingj to get the vib sensors registered?
i have some aqara contect sensor that i can’t pair in my hub v2 anymore if i change chanel right now i m on 15 i must pair everything again?
Hi @b16b , no you don’t but some devices may go offline and come back online again shortly after. I also suggest rebooting the hub after changing the channel.
Without knowing anything else you have deployed changing the channel should not be required.
What method are you using to try and register it?
