How to pair Aqara Wireless Remote Switch H1 Double Rocker (WRS-R02)
Hi guys,
I am new to the Smartthings IDE and want to pair this Zigbee switch to my V2 hub. When i hold down the switch buttons for 10 seconds they start to blink and i see a catchall event like this:
catchall: 0104 0006 01 FF 0000 02 7662 01 00 0000 02 00
Name Value
archivable true
commandId 0
date 2021-12-29 9:39:12.000 AM CET (2021-12-29T08:39:12.000Z)
description catchall: 0104 0006 01 FF 0000 02 7662 01 00 0000 02 00
displayed false
eventSource HUB
hubId 018bc6d6-8425-4ee2-83d8-5900601db033
id acd4526b-9e6e-41dd-9b7c-dac5fe22e9d0
isStateChange false
isVirtualHub false
linkText Oudenbosch hub
locationId 0cf76c34-7ba5-4f22-9c1b-6040eb9399c0
name catchall: 0104 0006 01 FF 0000 02 7662 01 00 0000 02 00
rawDescription
translatable false
unixTime 1640767152000
value catchall: 0104 0006 01 FF 0000 02 7662 01 00 0000 02 00
viewed false
I am just not sure what to do with this? The hub does not seem to recognize this device when in pairing mode using the Scan for nearby devices option?
Any ideas?
if you are able to use Edge drivers you can try
Hi,
I was able to install the Xiaomi/Aqara Switch and Button driver successfully.
Not sure what the next steps are to get this device paired? Sorry, newbe here!
This procedure works for pairing the cube, button, motion sensor, and temp/humidity sensor. I’ve not tried it with switches.
When adding device click “scan nearby”
First hold the button until LED goes off(about 3 seconds). It should flash once quickly. Then press it again. It should flash 3 times indicating it has connected to the hub. Continue pressing the pairing button between double flashes of the LED until the device shows up in the app. It will take a minute or so. If you’ve ever paired a universal tv remote without the code it’s similar to that.
So did this work for you?
Did you manage to make it work?
Yes it works but it has a delay of almost 1 second if i press a button. Kinda slow.
which mode are you using? Direct bind or hub ?
if Hub , could you please send a flagged log, maybe even a video… what is the amount of time between pressing the button and the entries in the log being received
Is there a way to switch the mode on the remote? The h1 double rocker. That is the reason of the slow response to the hub… i want it in the high speed click mode.
it might be faster with direct binding. but I doubt it is 50ms in the ST zigbee network.
I had the issue where the switch just toggles all my lights after pairing and doesn’t show up in Smartthings as a device. Just want to share how I finally got it paired correctly and working.
Prerequisite: Install driver from [Edge] Driver for Aqara Switches and Remotes
  1. In app, add device
  2. Scan nearby
  3. At the switch, press and hold the right button until the blue led flashes 3 times, and release
  4. Wait until the led flashes once
  5. Press and hold until the led flashes, release, then quickly press and hold again
  6. Repeat step 5, keep holding between flashes until you either see 2 flashes or the switch showing up in the app
  7. If you see 2 flashes and the switch doesn’t show up, repeat 3 to 5
I think it took me about 20 tries to get it to show up in the app, this is the third time I re-paired and it still works. I observed that holding the button between flashes seems to extend the pairing period. Hope this will help anyone having trouble with this switch.
Most likely your device model is not supported by the driver.
Without proper initialization, some Aqara devices behave in the way you described.
The WRS-R02 I’m referring here is in the driver fingerprint (v22). Button presses, double tap, hold all works once paired successfully. Just that the pairing process is an epic pain.
