Edge Driver for Aqara Dome Water Leak Sensor (19 Nov 2022)
I’m very new to Smartthings. I have been able to setup basic things like smart switches and an Aqara Temp and Humidity sensor. However I’m unable to setup the Aqara Dome Water Leak Sensor. I have downloaded some edge drivers, through channel invite links I’ve found, but none seem to work. I haven’t been able to find a channel invite specifically for Aqara devices. Any help anyone could provide would be greatly appreciated. Thanks!
couple of questions:
what is the specific model for Aqara?
when you find these channel links that don’t work… error messages? or links? or the post you found them? just trying to figure out that issue.
https://thingsthataresmart.wiki/index.php?title=Table_of_Edge_Drivers
I’m using the V3 SmartThings hub trying to connect the Aqara Water Leak Sensor. Model: SJCGQ11LM. I can open and download drivers successfully from channel invitation links I have found. But no drivers I’ve downloaded successfully allow me to see the status or any information regarding the sensor.
I’m using the “Zigbee Water Leak/Smoke Sensor 1.7” from:
Channel and Drivers Web UI (smartthings.com)
However at the moment they keep going offline and coming online again.
Same for the Aqara Motion sensor P1 and Aqara doorsensor.
is that channel still up? I’m trying to move my Aqara water leak sensors with no luck.
