There’s an ongoing problem with some Osram Lightify Bulbs where they will automatically turn themselves on randomly. This happens a lot to myself whilst everybody in the house is tucked up in bed.
The apparent ‘solution’ is to update the firmware on the lightify bulbs but I have the latest and this still tends to happen.
So… long story short I’m looking to come up with a CoRE piston that automatically turns the bulb off. Now I could do something simple like…
IF the time is between 12:00am and 6:00am AND the light turns on THEN turn off light.
But surely there must be a better and more robust way of doing this than that? For example, is it possible to do something which singles out requests e.g. If the request hasn’t come from CoRE / Alexa / SmartThings app then turn off the bulb.
What mechanism are you using to trigger the lights to turn on? My lights used to randomly come on until I used webcore to be the mechanism to turn the lights on and off.
I haven’t taken the leap to WebCore yet (still using CoRE v0.3.16d.20170828) but this has been an ongoing issue even before using CoRE at all.
It’s been a well documented issue across the various Osram Lightify threads on here.
I haven’t taken the time to read about WebCore yet, but I’m presuming it’s going to be a hassle upgrading all of my current pistons, which obviously I’m reluctant to do when everything is running smoothly.
Anyway… any ideas on what piston would solve my issues?
Great. Not sure how that helps solve my problem though?
My issue is turning a specific light OFF when they turn on through a method that I haven’t initiated e.g. either via CoRE / Alexa or the SmartThings app.
