Osram light turned on randomly
I installed a Sylvania Osram RGB bulb on Saturday. I had no problems connecting. Worked fine until around 4:30am, the light turned on. So I woke up and opened the app to find my hub was not working. I waited a few minutes, the hub started working but I could not get the light to turn off. I have it unplugged right now because I did not want to mess with it in the middle of the night. Is it my hub and or a problem with my light?
Could be hub, light, power fluctuation, bad app logic. Any number of things.
A firmware update will also turn it on I believe.
ah, yes. If you have OTW firmware for bulbs enabled, that too will cause them to come on.
