So - I have old alarm system - was thinking of getting Konnected but by now
I have a ton of wireless sensors
most of the wired window sensors are gone when we replaced windows
the old wired motion sensors are huge and clunky and I’m probably going to throw out
so it doesn’t quite make sense to get Konnected just for the one or two door remaining sensors I might like to use.
My question, though - would installing Konnected enable me to “expose” all my SmartThings sensors to Noonlight? That might be a worthwhile use case for me. (and yes, I’d be able to use the couple of remaining built-in door sensors I have left from old system).
You don’t need Konnected to expose your sensors to Noonlight. It works for any SmartThings sensors already. Just install the Noonlight SmartApp and DH.
Noonlight is a horrible service. Where is the contact number for noonight support - there isn’t one. The only way you can contact them is via a chat app on their web site (which doesn’t ever seem to be manned, it always says “we’ll be back”, or you can send them an email.
For security monitoring of my house, I want a real live person that I can talk to when there is a problem - for example - police showed to my house this afternoon, because of a “panic button” being tripped (we don’t have one) and we quit the noonlight service 2 weeks ago. No phone call was made to my house, to my cell, to my wife’s cell - no email was sent, no text message…but they sent the police.
Their monitoring is cheap, but without a way to contact these people immediately? Hopefully the police aren’t summoned again unnecessarily. I certainly don’t want them being called over and over again for nothing .
tgauchat
26
Unfortunately, you can’t expect much for only $10/month; though as they grow, their quality will hopefully improve.
Ring is also in a similar price range. I wonder what their quality is like…
These companies are linking platforms of questionable reliability (SmartThings with no cellular backup - unless you DIY with extra router failover and battery backup etc., etc.) directly to local services, with no professional installation, at “rock bottom” pricing. That’s a risky recipe. Not impossible to execute, but, undeniably difficult to do well.
Hi all,
I have Noonlight with Konnect.IO alarm panels.
In the past two weeks, I’ve had two incidents where SmartThings triggered the noonlight virtual alarm switch.
Home monitoring was off
None of the monitored sensors show tripped
The Noonlight virtual switch is the only thing that appears to activate.
Have you guys seen this?
I believe there have been two hub firmware updates recently, and these will take your hub off-line briefly. When it restarts your presence can be out of sync.
Unfortunately, as customers we are not given any way to defer or deny this kind of service loss, although they do try to give some advance notice.
The weird thing is no sensor tripped, no presence change happened.
Logs don’t show a reboot or reconnection of the hub.
It does show a light switch flipping on at the same time that the NoonLight virtual switch tripped.
But the light wasn’t actually on, so while the logs show the switch was turned on, it wasn’t actually turned on.
Puzzling.
Do you have Google Assistant integrated as well?
Google may think that “Noonlight” is a light switch. If you say “hey Google, turn on all the lights” that may trigger Noonlight to be turned on. Workaround is to exclude this switch from the ST <> Google integration.
Hey Nate -
I did this one! I had google assistant integrated with all Smartthings devices allowed to be accessed from Google Assistant. I accidently tripped the alarm by having Google switch on the noonlight switch. I subsequently blocked the noonlight virtual switch from Google.
So it’s not that. It’s strange that two switches (a light switch and the noonlight virtual switch) both flipped on at 6:01AM. No other sensors or devices were active at that time.
Hey Nate,
So I missed that the google Home integration changed. In the first version of the integration, you could select what devices Google could access. They upgraded and dropped that feature. Now google sees everything, including the NoonLight virtual switch.
I now suspect that Google switched the NoonLight alarm switch on as you suggested, since it’s no longer blocked from the integration.
Got any clever ideas for protecting the Noonlight virtual switch? I only want the home monitor to be able to switch it on.
