Have the replacements been chewing through batteries too?
Yes. That’s why I am leaning toward the positioning being the culprit.
Just doesn’t make sense, because one of the well-behaved ones is the furthest away from the hub, through two extra walls.
Functionally, however, they all perform very well.
- Nate
Could it be that they are in higher traffic locations? 3-4 weeks of s pretty dismal though. Both of mine still say 100% so I’m hoping they won’t be as bad as 3-4 weeks. I’ll look into getting some rechargeable batteries for them and my iris open/close sensor.
Nope. Both are in very low traffic areas, pointing at sliding glass doors. Within a week, they go to 77%, and then 66%, with one even reporting -33% at one point … That was the first one to get returned!
Let me know how the rechargable CR123A’s go… I was thinking of picking up a boatload on Amazon, because the Arlos use the same battery type.
- Nate
My iris open/close sensor never said 100% it started at 88% then went to 77% in about 2 weeks. I had removed a cree bulb from the room it is in and I guess it was on the outskirts of the zigbee network and started reporting open when it wasn’t so I reset and readded it before realising the removal of the bulb was the issue. Battery went back to 88% though and has been operating perfectly ever since. Though I love the size of the iris motion sensors it may have been a better option if they had made it slightly bigger and used the larger cr123a battery which has higher capacity and this lasts much longer. Still an awesome sensor though!
I have to laugh, because the support site identifies the battery as a CR2450, but the video shows the CR2 in the device… LOL!
https://support.irisbylowes.com/link/portal/30143/30206/Article/541/Iris-Motion-Sensor
I’ve emailed them a few times since I bought my first one, early this year, they refuse to respond or change it. Wonder how many people order those and get pissed they don’t fit!
And it is CR2 not CR123A, BIG difference, not compatible with one another. CR2’s are pricey too, Digikey sells real Panasonics for $2.60 a pop. Most stores have them at $5. The 2450’s are only a buck.
I have some of these nearly a year old well over 20ft that are still reporting 77.5%.
Do a complete reset on yours @toyanucci, pull the battery, push the button in, replace the battery, rerun discovery, it will redetect. Make sure NO lights are on or come on other than green when it detects motion.
Is there a way to control the temperature reporting frequency? I am finding they are VERY slow to react to temp changes and even if I hit refresh they frequently don’t respond for a while. I am using the DH SmartSense Motion Sensor but I noticed earlier in this thread people were saying to use the SmartSense Motion/Temp DH but I can’t find that. Has it been renamed? I recently got some Ecobee Lites and am trying to use the DH developed by yvesracine. The code is faithfully adjusting the temp up due to the sensor in my bedroom. . . but that room has a lot more vents so heats up fast and the sensor is so slow to respond that the thermostat keeps getting adjust up to compensate. Suggestions?
It reports when the temp changes 2 degrees I think. This was discussed elsewhere but honestly don’t remember where it when.
Shouldn’t need to poll it, but I know you also don’t want it checking constantly, will murder your battery life.
I posted a custom DTH for this device here:
Amazon has good deals on the CR2’s and the CR123’s and their Duracell Ultra Lithium. 12 CR2’s for $21.45 and 8 CR123’s for $14.91…
Links? I’ve gotten so many fakes from Amazon, you have to be real careful with those.
Here you go.
https://www.amazon.com/gp/product/B00C8WGDB8/ref=oh_aui_detailpage_o03_s01?ie=UTF8&psc=1
Look legit, as long as the image is what you really get. The expiration date needs to be embossed, not printed, made in USA is a good sign. Might order some of the CR2’s and compare, that’s a lot cheaper than they should be though…Spidey Sense is tingling.
It is what you get, I ordered both a couple months back, all have exp dates in 2024…
I ordered the 8 pack when i had the bad motion sensor that died every week. I’ll admit I didn’t check the dates, but the battery did work.
Which seller did you order from?
The CR2’s we’re DD Supply…
The CR123’s were All Photo Inc…
Consider posting/linking to the batteries thread:
Is there a warranty on these? I have 5 and 1 has consistently burned through batteries. Last battery lasted about 2 weeks. I bought 2 from Lowes and 2 from Amazon and not exactly sure where the problem one came from. Any suggestions on the best way to get it replaced?
