953 is already paired an poo/spa button works
config log:
23dd1a16-fdf7-42da-aca4-5c65d96476d8 7:30:26 AM: debug <<<<< rspFlg=true dly:1000.0/1000.0
<<<<< Event: [name:swVSP2, value:on, isStateChange:true, displayed:true, descriptionText:(swVSP2 set to on), linkText:Pool Controller]
<<<<< Event: [name:temperature, value:84, unit:F, displayed:false, isStateChange:true, linkText:Pool Controller, descriptionText:Pool Controller temperature is 84°F]
<<<<< Event: [name:airTempFreeze, value:50, unit:F, displayed:false, isStateChange:false, linkText:Pool Controller, descriptionText:Pool Controller air temp freeze is 50°F]
<<<<< Event: [name:airTempSolar, value:0, unit:F, displayed:false, isStateChange:false, linkText:Pool Controller, descriptionText:Pool Controller air temp solar is 0°F]
<<<<< Event: [name:clock, value:07:30, displayed:false, descriptionText:PE653 Clock: 07:30, isStateChange:true, linkText:Pool Controller]
23dd1a16-fdf7-42da-aca4-5c65d96476d8 7:30:26 AM: debug ManufacturerProprietary event, [1]:40 [4]:84 payload: 05 40 02 02 84 00 10 02 12 00 02 01 54 32 00 07 1E 01 00 00 02 03 04 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
23dd1a16-fdf7-42da-aca4-5c65d96476d8 7:30:25 AM: debug ManufacturerProprietary event, [1]:40 [4]:87 payload: 05 40 02 02 87 00 10 02 00 00 00 07 00 00 00 00 00 10 04 00 00 00 00 00 07 1E 01 01 00 00 20 00 00 00 00 00 00 00 00 00
23dd1a16-fdf7-42da-aca4-5c65d96476d8 7:30:24 AM: debug >>>>> ConfigurationReport(parameterNumber: 22, scaledConfigurationValue: 2, reserved11: 0, size: 1, configurationValue: [2]) - description:zw device: 07, command: 7006, payload: 16 01 02
23dd1a16-fdf7-42da-aca4-5c65d96476d8 7:30:23 AM: debug <<<<< rspFlg=true dly:1000.0/1000.0
<<<<< Event: [value:3, name:temperatureOffsets, displayed:true, isStateChange:true, linkText:Pool Controller, descriptionText:Pool Controller temperature offsets is 3]
23dd1a16-fdf7-42da-aca4-5c65d96476d8 7:30:23 AM: debug >>>>> ConfigurationReport(parameterNumber: 3, scaledConfigurationValue: 50331648, reserved11: 0, size: 4, configurationValue: [3, 0, 0, 0]) - description:zw device: 07, command: 7006, payload: 03 04 03 00 00 00
23dd1a16-fdf7-42da-aca4-5c65d96476d8 7:30:22 AM: debug <<<<< rspFlg=true dly:1000.0/1000.0
<<<<< Event: [value:0, name:firemanTimeout, displayed:true, isStateChange:false, linkText:Pool Controller, descriptionText:Pool Controller fireman timeout is 0]
23dd1a16-fdf7-42da-aca4-5c65d96476d8 7:30:22 AM: debug >>>>> ConfigurationReport(parameterNumber: 2, scaledConfigurationValue: 0, reserved11: 0, size: 2, configurationValue: [0, 0]) - description:zw device: 07, command: 7006, payload: 02 02 00 00
23dd1a16-fdf7-42da-aca4-5c65d96476d8 7:30:21 AM: debug <<<<< rspFlg=true dly:1000.0/1000.0
<<<<< Event: [value:5, name:operationMode, displayed:true, isStateChange:false, linkText:Pool Controller, descriptionText:Pool Controller operation mode is 5]
23dd1a16-fdf7-42da-aca4-5c65d96476d8 7:30:21 AM: debug >>>>> ConfigurationReport(parameterNumber: 1, scaledConfigurationValue: 1281, reserved11: 0, size: 2, configurationValue: [5, 1]) - description:zw device: 07, command: 7006, payload: 01 02 05 01
23dd1a16-fdf7-42da-aca4-5c65d96476d8 7:30:16 AM: debug <<<<< rspFlg=false dly:1000.0/1000.0
<<<<< Dev cmd: ConfigurationSet(parameterNumber: 1, scaledConfigurationValue: 1281, reserved11: 0, defaultValue: false, size: 2, configurationValue: [5, 1]) --> 700401020501, delay 1000.0
<<<<< Dev cmd: ConfigurationSet(parameterNumber: 3, scaledConfigurationValue: 50331648, reserved11: 0, defaultValue: false, size: 4, configurationValue: [3, 0, 0, 0]) --> 7004030403000000, delay 1000.0
<<<<< Dev cmd: ConfigurationSet(parameterNumber: 2, scaledConfigurationValue: 0, reserved11: 0, defaultValue: false, size: 1, configurationValue: [0]) --> 7004020100, delay 1000.0
<<<<< Dev cmd: ConfigurationSet(parameterNumber: 22, scaledConfigurationValue: 2, reserved11: 0, defaultValue: false, size: 1, configurationValue: [2]) --> 7004160102, delay 1000.0
<<<<< Dev cmd: ConfigurationGet(parameterNumber: 1) --> 700501, delay 1000.0
<<<<< Dev cmd: ConfigurationGet(parameterNumber: 2) --> 700502, delay 1000.0
<<<<< Dev cmd: ConfigurationGet(parameterNumber: 3) --> 700503, delay 1000.0
<<<<< Dev cmd: ConfigurationGet(parameterNumber: 22) --> 700516, delay 1000.0
<<<<< HubAction: 910005400102870301, delay 1000.0
<<<<< HubAction: 910005400101830101
23dd1a16-fdf7-42da-aca4-5c65d96476d8 7:30:16 AM: debug RemoveChildDevices(before) count=0 children:
23dd1a16-fdf7-42da-aca4-5c65d96476d8 7:30:16 AM: debug Existing children: [Pool - Switch 1, Pool - Switch 3, Pool - Switch 5, Pool - Switch 2, Pool - Switch 4, Pool - Spa Mode, Pool - Speed 1, Pool - Speed 2, Pool - Speed 3, Pool - Speed 4]
23dd1a16-fdf7-42da-aca4-5c65d96476d8 7:30:16 AM: debug +++++ updated() DTH:Ver 3.05 state.Versioninfo=Versions: Firmware v3.4 DTH: Ver 3.05 zWaveLibraryType: 6 zWaveProtocol: v2.78 state.ManufacturerInfo=ManufacturerInfo: manufacturerId: 5, manufacturerName: Intermatic, productId: 1619, productTypeId: 20549
