I am suck, so I’m reaching out to all of to see if you might be able to help. I’ve been working with tech support for weeks and getting nowhere.
Background:
Been a user for about 10 years, not a developer by any means, but pretty proficient using the basic system
70ish devices, mostly dimmers, switches, buttons, and a few sensors.
2 Aeotec v3 hubs (software up to date)
Problematic devices that I can’t add - GE Enbrighten dimmer ZW3005, UltraPro dimmer ZW 3010, and UltraPro switch ZWA4011ULT (there are a lot of these operating successfully around the house currently).
Done all the normal things….exclude, reset, disconnect power (and air gapped), etc. To add, I’ve tried search, QR (on the devices with one), partner device (Tried GE, Jasco)…nothing will kick them into getting discovered.
Support tells me to do all the stuff I know how to do, or to send them the logs…and they can’t find anything.
I had this problem a year or so ago when I downloaded the edge driver most people use. For some reason, that made new devices undiscoverable. When I deleted that driver, I could add my 30 new devices in about an hour, so I never downloaded drivers after that.
I see new drivers in the hub that I did not add (I read other threads about this). I deleted them, tried to add the dimmers…nothing. The drivers (wemo, Sonos, JBL, etc) all showed back up.
I’m at a loss. Just finished the bathroom remodel and I can’t get the final bedroom/bathroom dimmers connected.
Anyone have any ideas?
Thanks in advance!
Jeff
