Newbie considering buying and need some info about hive
Hi
if I buy a smarthing HUB and want to control hive via it. THe question is do I need the hive HUB as well as the smart things hub. ALso would I be able to use Alexa to control my heating.
The same goes for Hue any help would be great.
One last thing can I control Lightwave devices i.e light switches or is there a light switch that can be controlled
You can add Hue bulbs directly to the ST Hub, but I would recommend getting a Hue hub. It has some functionality in managing Hues, and is supported/recommended.
Here is a long thread about it:
I moved this to UK category so you could get some visibility around your Hive and Lightwave questions…
What exactly is the “functionality” that the Hue hub has and ST does not? I had the bulbs under the Hue Hub and I couldn’t even make them blink or change colors on their own. Did I miss something? I have since removed them from the Hue Hub and connected them directly to the ST hub - now I can have color loops on them… and make them blink, breathe, etc…
PS: I am not being sarcastic, the question is real, what is this functionality that I am not getting via ST?
  • Native App has some neat features (I rarely use it though)
  • Third party app integration. There are tons of Android/iOS apps that you can use. I use the Party mode to make the lights flicker to music, and to Halloween sounds.
  • Firmware updating of the bulbs.
  • Its difficult to remove the Hue bulbs from ST.
  • Being able to use the Hue remote. I have one mounted on my wall to control some lights.
ST still recommends the Hue Hub.
Can’t you do the color loops with the Hue Hub?
edit: are you using the “Enhanced Zigbee Handler”?
OK so for Hive - you’re good to go. There’s a Hive device type (in fact two - one for water and one for heating) and all the associated apps. See here: [RELEASE] - Hive (Connect) V2.6 (British Gas Hive)
You do need the Hive Hub though, it won’t work without. British Gas claim this is because they use a proprietary communication protocol, I sense this is rubbish since they said the same thing about their plugs and people have got those working fine.
As it makes Hive appear to ST as just another thermostat, anything that works with Thermostats will work with Hive. I’ve got mine controlled via SmartTiles, I can operate it with CoRE and so on.It’s a fantastic bit of code.
You can also work Hive through Alexa, but that’s using Alexa’s own Hive skill - you could use Ask Alexa on ST to work it, but that seems a lot of work for no benefit. The Hive skills for me work just fine.
Hue I see is covered above, I use the Hue Hub but I see there’s quite a lot of success in connecting them directly. I may liberate a single bulb and try it out. For me, if I swapped them and it stopped working that would be the ultimate fail as it’s the lighting that my family use the most.
I was using the standard hue bulb in ST - but the Hue app did not allow me to do party mode, loop, flicker, etc. The Hue app was in fact so basic I rarely used it. So what are the neat features of that app? :frowning:
I guess updating the bulbs would have been nice - and I am interested in the party app - is that the Hue app being able to do it or third party?
Hue app is limiting, does have some nice scenes but that is about it.
Here is a list of apps that extend Hue hub. Don’t remember the one I used (been a while) but it used the phones mic to control the lights.
I think for most users using the Hue Hub is easier and supported. If it’s for 1 or 2 bulbs may bypass it (I have 8 right now)
Here is a good reason to update the bulbs.
Anyone know if the Hive bulb can connect directly to the ST hub?
Unknown, I started a thread a few weeks back but no reply.
In theory, yes they should function as they are ZigBee HA 1.2, but limitations are presently unknown!
Next time I need a bulb, it will probably be a Hive bulb but a while off that yet!
