I’m so new to the ST community that I haven’t received my hub yet
I just moved into a new house, and I’ve completed a couple of very simple HA tasks, I put a $20 motion detector on a closet light (open door, light on) and a bought a WeMo outlet so that the low voltage landscape lights now are set to turn on and off with dawn and dusk (sunrise/sunset times).
Now I’m determined to take this “old” ADT alarm system and turn it into something more useful. The system is composed of a DSC IMPASSA self contained unit (re branded by ADT). It has a cell module in it, but they hooked it to a Netgear “Pulse” router because the house is located “in a hole” where there is NO cell signal. I have to use WiFi calling and an ATT Microcell.
After doing hours of research I learned the installer code and started learning to re-program the panel. I’m currently looking for some assistance so that I don’t go down the wrong path…
I assume that I will need to replace the Netgear “Pulse” router with a Eyez-On EVL-4CG via the 4 wire connection to the panel. However I am assuming that the wireless DSC sensors use a propitiatory protocol and that a ST hub would not be able to communicate directly with those sensors. meaning the “IMPASSA” panel must have the correct radio and protocols to communicate with the sensors.
I figure this could go one of two ways…
ST hub able to communicate directly with the DSC wireless sensors? - if that’s the case then I don’t necessarily need the ADT keypads, but my wife is used to punching in a code to control an alarm system so I may need them anyway
ST hub is NOT able to communicate directly with the wireless sensors? - This means I must use the panel I have to be able use the sensors already in the house, and ST would be able to help with what I would call “nice to have” items (one use case - Turn on a Z Wave switch to an entry hall light when the door near that light is opened so that you can see to work the keypad).
I’ve spent the better part of the last 6 hours reading up on these topics, finding user manuals, re-programming keypads etc.
I suppose one option would be to replace all the sensors, but the house has more than 20 sensors currently, seems a big shame to not be able to re-use them for just the cost of batteries.
So before I go spending money in the wrong places, are there any “latest updates” to be found on this topic? All my searches turned up threads from 2014 and 2015.
Thanks in advance!
