Hi everyone. farily new to all this but I got almost everything working. using the ST hub v3 and I already had Lutron caseta dimmers throughout, so I got the lutron bridge and everything works great and joined nicely!
on to automation, got them all set but noticed 2 things missing…
cannot set to on sunset and off at a specific time. Unless I’m missing something, is there a way to do this or only on/off at specific time or on/off sunset to sunrise? I like for lights to come on at sunset and off at say 12:00am or a set time, not stay on all night…
This leads to next question…
how do you set the location for so it knows local sunset? I cannot find that anywhere in the app.
I’m using the new app and I do see where it finds your location based on if you’re phone is home but I don’t want sunset determined based on where my phone location is… how do you set the location of where the hub is for sunset times ?
thanks in advance. everything is fairly easy to use and automations are great so far, what a convenience. I’m sorry if this topic has been addressed already, I’ll search again but didn’t see this exact topic.
For the automation question, your observation is correct. Create two smart lighting automations. One for turning on at sunset and another for off at a specific time.
thanks. for some reason it did not work… perhaps because that trigger was already set at a time and was on… I’ll try again tomorrow.
one more question, I have all my “dimmers” on one automation and set to come on a dim to a level, can I also add my 2 lamps to that automation even though they only come one and off no dim? It did give those as options to add but I wasn’t sure if it would be a problem if it tried to “dim” the on/off lamp or does it somehow know and just turn that one on and dim the dimmers?
