I am trying to turn on a my front porch light at sunset, but don’t see that option under Automation>Automatically Perform>At A Certain Time
I only see a specific time…not Sunset as the ST documentation suggests should be an option. My only thought is there is a setting somewhere else where I set the time zone or something so the ST knows when sunset is in my area?
Side note: I also tried to set this up through the Smart Lights SmartApp, but 1) it gave me an error while saving when I tried to add a 15 minute offset and 2) the error went away when I removed the offset, however the automation is not working.
In the Samsung Connect app, click on the Devices tab. At the very top in the center is a pull-down selection, choose your Home location instead of All Devices. Next, click on the 3 dots in the upper right of the screen and select Edit. You will see the geolocation section on that screen.
