It’s coming! Hopefully before the end of March.
hey Tyler - any update on this at all? I just shot a note to smartthings support.
i’m guessing no reply means no update.
Just purchased a couple of the 910 model 450191 deadbolts and can get it to pair with ST just fine. However, I can not get the device to open or close using ST. I’ve tried setting up/removing several times including deleting directly from the IDE. I’ve also rebooted the hub just to be sure. Any suggestions before I return them?
Note also that when I hit the device from my things menu on the android app, the red light on the lock flashes. However, the lock doesn’t open/close or change status, just shows perpetually as “unlocking”
I’ve found with my lock, that it paired fine but would not update or respond to lock commands in one of two cases. The hub or closest ZigBee repeater is too far away or the batteries are not fully charged. I added a repeater about 4’ away and replaced the included batteries with name brand ones (My Yale lock included batteries that were poor). Haven’t had a problem since.
Only other thing to say is make sure that your 910 is the HA 1.2 version and not Control4, though I don’t think the Control4 versions would even pair.
Thanks for the information. The lock is less than 18 inches away from two zwave light switches that are also repeaters so connectivity shouldn’t be an issue. Since I ordered two devices, I tried the second one and that one worked perfectly so I suspect that I have some type of defective device. Back to Amazon for a replacement.
Almost a year any news yet?
I don’t think zigbee support is coming. I am going to go ahead and buy the zwave module for the lock…this will guarantee the zigbee release soon
I’ve been using a Yale ZigBee YRD240 with no issues for months. In fact I have written a DTH with lock codes to work with lock managers. See below:
Thanks…just in time! I was about to start looking on Amazon.
