I am experiencing the exact same thing. Something is wrong with the device type or the platform with these locks. My Yale YRD240 was working perfectly until a few days ago. Nothing is wrong with your lock or your setup.
Submit a support ticket.
Cheers,
Scott
Same issue here kwikset 914 - handedness works and updates the smartthings status⌠but the locking/unlocking via st does nothing
going to log a ticket⌠tho it seems there are huge delays.
@tycalmc @av8rdude @joel_eggenhuize Please shoot an email to support@smartthings.com and note your account email address, if you havenât already done so. Please also note to the Support Rep to flag me, Donald Kirker, for the ticket. I am going to watch for three tickets. I just paired a 910 and see an issue, but I want to see if it is the same problem for all three of you before I get all excited and jump up and down.
I will be checking in with Support in the morning, as this may impact more than just you. (Even if it does just impact you, I will be checking none-the-less.)
I already sent an email in but i will send another one with this information. Thank you for your help. I was able to finally get it to work with some changes in code on my end, with the use of @sebirdman and his code at https://github.com/sebirdman/Kwikset-ZigBee-Lock/blob/master/Kwikset%20Zigbee%20Lock.groovy
@dckirker - I just entered a support ticket with the same scenario as well. Thanks in advance for your help
Thanks folks. I have discovered part of the issue and am working to have it resolved. I donât have a specific timeline as of yet. More to come. If the device is paired, for the moment, donât unpair and repair it as it wonât resolve the issue â currently.
Brand new SmartThings user trying to pair Kwikset 916 locks. New hub and new locks not pairing yet. Lock mechanism is 1 foot away from hub. Per Kwikset instructions, 4 presses on Button A to enable zigbee pairing. Wore my phone battery down looking for devices. Will have to try again in the morning. I have a 914 installed on house already and not able to get it paired either.
Have you attempted to reset the device per this page:
https://support.smartthings.com/hc/en-us/articles/205151273-Kwikset-SmartCode-916-Touchscreen-Electronic-Deadbolt
Let me know!
Yes, I have gone through the reset process thinking it was zigbee. The very small sticker on the box appears to indicate it is z-Wave instead. Model 450191 end of fcc id is ZWV which makes it more certain to me. I have tried the single click zWave pairing with no luck. I removed the battery and started process all over again. My hub shows no devices as of yet.
Youâll likely need to initiate the Exclusion/Reset process in that article as well. Did you try that yet? If itâs successful the mobile app will let you know that youâve successfully reset a device.
My Yale YRD240-HA started working perfectly two days ago. Whatever you did fixed itâŚthanks!
Spent evening messing with the locks again. I called Kwikset support and we determined the reason exclusion/inclusion was not working was radio was bad. I had purchased 2 916 locks from Amazon Marketplace and both turned out to be bad. The 914 which I purchased direct from Amazon is working fine so far.
Hey @Tyler, the link you put for Kwikset 910 is actually for the touchpad version not the touchscreen⌠Is the touchpad version also compatible with ST? Because iâm planning to get oneâŚ
Yes, weâre compatible with the ZigBee Kwikset 910 Touchpad.
my lock worked again for a while and has now stopped - hasnât worked for about 3 days - it is not even showing handed turns. Batteryâs â say 80% and the pin function and lock function manually works fine - plenty of power on the motor.
Anyone else seeing similar issues again? i have not re added it just yet⌠quite annoying having to do it so often.
my smartthings setup seems to be stable for about a month then i have to spend an hour re jigging. - donât get me wrong - love it, but itâs getting on my nerves with a few other issues iâm having.
Edit: was just about to remove and readd device but it started working again⌠hmm
Hi @Tyler , did you ever get an official answer to whether or not the ZBC4 models of the Kwikset 910 are fully supported?
Thanks,
No, weâre not compatible with the C4 models.
hi @Tyler, is the Kwikset SmartcCode 914 Zigbee version compatible with UK ST hub? If not by default, can it get to work through a custom devices type/handler? Thanks!
Yeah it should work! Weâre not doing anything in our cloud that would prevent you from pairing that device to a UK hub,
Tyler how about support for programming remote user codes in the Device Handler for ZigBee like Z-Wave locks?
