I tried pairing my z-thermostat into smarthings hub . they have detected them as energy meter and doesnt give me much options to control the device from my app
Based on internet search it says that driver needs to be updated correctly. any help on this is appreciated.
Just open the link and follow the steps as they are presented.
Once the driver is installed try switching the driver via the mobile app. 3 dots in upper right corner > driver > switch driver > select the “Mc” driver.
Are you saying you don’t get an option to install the “Z-Wave Thermostat Mc” driver when you go to the supplied link?
Or are you saying you installed the driver and you don’t see it listed under the list of installed drivers on your hub? To view a list installed drivers in the mobile app, open the hub tile > 3 dots in upper right > select drivers
Or are you saying the driver is installed on your hub, but you can’t see it when trying to change drivers?
