Life was wonderful with the Groovy DTH. The device worked flawlessly for months.
In my journey to Edge Devices, I moved this device to the GE Z-Wave Switch/Dimmer/Fan/Outlet from @philh30. This driver worked well for some of my other devices.
However, it’s not working for the GE ZW4203. As I described in another thread, I get a spinning disk followed by a network/server error message if I try to control the device from the SmartThings UI. Controlling from the device works fine.
Ok, so it’s too early to jump off the Groovy dinghy. But now I am stuck. There is NO was to revert that driver to the DTH as I am using Phil’s driver for other devices.
This forum was set up a number of years ago so that customers could help other customers. It’s not officially monitored by smartthings employees except for a few of the developer sections.
To get help from support, you need to contact one of the official support channels. See the bottom of the following page:
The first person you get will probably just be a Samsung employee reading off a script, but if you hang in there, eventually it will get escalated to the smartthings technical team.
