The only devices I can attach are the Smartthings Door sensors. Nothing else will work.
- Fortrezz Siren
- Pressed program button twice and tried to join.
- EcoLink Motion Sensors
Per directions, pulling battery for 5 seconds, then putting the cover back on puts this unit in inclusion mode. . - GE Zwave Toggle Switches.
Toggled On and Off on 3 different switches and nothing. The First switch is about 15 feet from the hub. Tried Exclusion mode from the Hub. Then tried to reset the switch following instructions here: https://support.smartthings.com/hc/en-us/articles/205236370-Connecting-the-GE-In-Wall-Smart-Switch-45856GE-with-the-SmartThings-Hub I tapped the top rocker 10 times and the LED did not blink.
