Hello and good day.
At the end of last year I installed a “Nuki Smart Lock Gen.4” in my apartment. Compatibility with Smartthings is advertised by the manufacturer Nuki:
“The new Matter communication standard now enables seamless and local integration of your Smart Lock (4th generation) with Apple Home, Google Home and Samsung SmartThings.”
The Matter connection with Smartthings works with one limitation: the app interface only supports opening and closing, while the web interface also shows unlatch in addition to lock and unlock. However, Unlatch is not running here on my.smartthings.com either.
According to the manufacturer, the following requirements must be met for thread support:
You need a suitable smart home hub that Matter via Thread supports. If you want to use not only the Matter integration but also remote access via Thread, the Smart Home Hub must allow internet access and support NAT64. Only when NAT64 is enabled do Thread devices have access to the Internet.
The following smart home hubs currently meet these requirements:
- Apple TV
- Apple HomePod
- Apple HomePod Mini
- Google Nest Wi-Fi Pro
- Home Assistant
I use the Aeotec V3_Hub with firmware 53.19 as well as current drivers in SmartThings (including beta). The Nuki-Lock firmware is also up to date. Lock’s matter status is currently 1.2.
My two questions are:
Why doesn’t the SmartThings Matter-Lock driver support the unlatch function?
Can someone here possibly explain what NAT64 is all about and why some Thread Border Routers support it but the Aeotec Hub V3 doesn’t?
