Nanoleaf Smarter Series "disconnected" today
Woke up this morning to my Nanoleaf Lines not being able to be controlled. I got a notification from Smartthings (very slick, btw) that Nanoleaf Smarter Series was disconnected, and I should tap to reconnect.
However, when I click on the reconnect and start the login procedure, SmartThings attempts a OAUTH login to Nanoleaf which redirects me to my.nanoleaf.me (followed by client ID keys, etc, passed via the URL) which winds up being a “Bad Gateway” page. I’m assuming this is coming from Nanoleaf, of course. Did they change the webservice login procedure?
I am going to delete my Nanoleaf lines and the Nanoleaf linked service and start again, in case something got stale, but I wanted to see if anyone here is experiencing this first?
Maybe related:
https://reddit.com/comments/1ey2rs4
And this:
just got my first 12 Nanoleaf Shapes. I want to controll it through the desktop app, but the download doesnt work, i always get 502 bad gateway. Any other option to get the App? cant find anything else on google
https://reddit.com/comments/1ey18j4
Same problem here but seems to work again.
Hi, @uberrob
Please let me know if you still see an error when trying to add the Nanoleaf integration.
In that case, we can investigate if there are error logs registered on our side.
Hi @nayelyz (and everyone).
Like others on here have reported it simply started working about a day after I posted this.
Thanks for checking in everyone.
I’m addicted to this, I’ve been having the same problem for over a week now. I removed it and can’t add it back. Same bad gateway.
Hi, @Strallek. Welcome to the SmartThings Community!
So, you also are trying to add the Nanoleaf integration but you get the error “Bad gateway”?
Could you provide the following, please?
  1. Screen recording showing the process you follow to get the error
  2. After you replicate the error, collect the app logs:
    1. Go to Menu > Gear Icon > About SmartThings
    2. Tap the SmartThings logo 10 times.
    3. This will open the developer’s space > tap ‘report a problem’
    4. This will generate a log file which we need you to send to build@smartthings.com
  3. Confirm the email account registered in the forum is the same one you use for SmartThings. If not, please share it with me over DM
  4. Enable support access to your account:
Hi @nayelyz
I’m having the exact same issue again today - same symptoms as my original post at the start of this thread.
Rob
If you’re interested, I’d love for you to check out the Nanoleaf driver I created for local execution.
Your feedback and contributions would be incredibly valuable!
Hi, @uberrob
Could you provide the information I requested above, please? The engineering team will ask for this information.
Hi @nayelyz -
Thanks for reaching back out… just like last time, I woke up this morning and
the accounts relinked by themselves.
Can you find out why this is happening? It’s not frequent, but it is quite irritating.
Rob
I can ask the engineering team to see if there are any errors in the logs that could help identify where the issue is.
For that, I need a timestamp of when they went offline including your timezone
and an approximate timestamp of when they came back as well.
Also, support access to your account to get the ID of your installation to look for it in the logs.
  5. Select the time period and confirm - In this step, please select “Until turned off”, once the team finishes, we’ll let you know so you can disable it again
Issue between SmartThings & nanoleaf Smarter Series connection since circa 20-Jan-25, my nanoleaf devices are reading offline in SmartThings and causing issues with routines etc.
Still active in nanoleaf and Apple Home.
I have tried resetting a nanoleaf device and relinking the service.
Message returned in my.smartthings
“Device Unavailable: The partner is informing SmartThings that the device is temporarily unavailable. Try again in 5 minutes. If problems persist, contact the partner for support.”
Hi, @jpd
Just to confirm I understand your issue:
  1. Your devices went offline
  2. You tried to reset those devices with no effect
  3. You relinked the service, but, did this create the devices online and then they were marked offline or they were offline since the installation?
  4. All of the devices discovered by the Nanoleaf service go offline, right?
Based on your answers to the questions above, I’ll ask for the corresponding information to open an investigation.
Late yesterday everything came back online (Nanoleaf and Sonos)
No network configuration changes made
Just received from nanoleaf
" … This week, some users experienced disruptions with our Nanoleaf Cloud, which may have affected remote control through the app or integrations with other smart home systems.
Current Status:
The Nanoleaf Cloud service is now stable. The issue has been resolved, and we’re monitoring the system to ensure continued reliability."
You can monitor the status of nanoleaf athttps://status.nanoleaf.me/
ok, @jpd
Thanks for letting me know. I’m glad this is working again.
