My Devices Error 500: Internal Server Error
Hi,
I’ve been playing around trying to find a better device handler for my Eria dimmer switch and It seemed to have corrupted my device. I am no longer able to see my devices in Smartthings IDE as well as Webcore.
When navigating to “My Devices” I get the following error.
Error
URI
/device/show/60fbfb2e-be0d-480d-a451-339071d0a4ff
Reference Id
a5e9797a-c2e3-4f02-98cc-eeaaec1ea371
Date
Sun Jun 13 20:22:04 UTC 2021
When I navigate to the corrupt device from “My Hubs” I get the following error
Error
URI
Reference Id
52367564-6fe1-456b-b5a4-c9460c60acb8
Date
Sun Jun 13 20:33:20 UTC 2021
Device info from “My Hubs” device list.
Master Bedroom Remote    Zigbee Multi Button    00158D00019952AC    F717
No errors when navigating to any other device via “My Hubs”
“Live Logging” keeps return this error every 15 seconds or so… Not sure if it’s related
54388979-05a7-49b9-95be-4262529170b6 4:47:26 PM: error java.lang.NullPointerException: Cannot get property 'customAttributes' on null object @line 176 (doCall)
  • I tried deleting the device from the mobile app
  • I removed the the device handler that I suspect is the cause of the corruption.
  • I re-added the device handler but still no change.
  • Suspected culprit device handler: cgmckeever/smartthings:eria-hold
  • I tried logging into the Smartthings IDE from other devices (same error)
  • Checked other posts with simillar issues, and it seems that the only way to resolve this issue is from the backend at Smartthings.
Hope someone can help…
Thanks.
Sylvain.
Open a support ticket with ST support.
Tagging @Brad_ST
Support ticket submitted.
Sylvain.
Looks like everything is working again.
Shortly after I submitted the support ticket, everything started working.
Thank you to whoever made the changes!! I really appreciate it!!.
Sylvain.
Sorry to bug you @Brad_ST, but can you look at my ticket for this issue? Ticket # is 1251974. Thank you!
