Had a good search on this and can’t find anything up to date.
You can now have 2 hubs in one account and for ST own devices this has been working for me great.
However I’ve gone to add some Z-Wave devices today and I just can’t seem to add them through the new app on either hub? They add just fine on the old app but this seems to support the first hub.
Repeater’s use up hops though. My issue is I’m running out of hops.
Depends on the deivce, some are not in the list to pick so usually wait for them to appear. Now Ive split back to two locations it seems to work again but now idea what I could do to get it back under one.
But you get 4 hops. That’s a range of 240 feet in any one direction. I’ve seen reports of people with 4,000 sqft single story homes not requiring anything more than repeaters for their Z-wave and Zigbee mesh networks. So, unless you’ve tried it, I wouldn’t automatically assume that you are having a problem. You might think you’re running out of hops just because that’s the route it chose that has the best performance but if you extended the network the device would choose a route that takes less hops. I wouldn’t assume that you’d run out of hops first. But if you are running into that problem, you might want to look at Zigbee instead. That allows for 15 hops.
I don’t think you can have multiple hubs in one location. Each hub would need it’s own location.
Maybe for STSC but not in classic. Plus, if they are in the same location, you can still only control one hub at a time, so what difference does that make? You’re still not getting them all under one umbrella.
Ive definitely tried it, for about a year! It works but very unreliably, its usually rain that kills it off totally. 2 hubs works far better.
Zigbee just doesn’t have the range of devices, especially for garage door and gate controllers for example. Plus I have the zwave modules!
Having them at the same location makes then available in the same instance of webcore which is what is important to me. I don’t control anything by the app in daily use. I call pistons in webcore from my own app.
Just seems like an annoying bug and wondered if anyone else had tried and failed or succeeded?
