Multi Water Valves and Multi Moisture sensor
Community,
I’m trying for find an application that will allow me to have more control over leaks. Instead of shutdown everything if there is a leak in part of the system, I’m trying to isolate the issue and allow the reset of the system to function as expected.
What I’m trying to do a monitor Leaks in different areas.
Example. I have a pump for the furnace that pumps condensation to a location.
Another moisture sensor to let me know Hot Water is and issue and turn off the water.
Another moisture sensor to let me know if there is a problem with Dishware and turn off another valve.
Is there anything that can accomplish this?
Thanks,
J
CoRE can do this.
Just create pistons for each location you want targets.
If Leak Sensor A detects a leak, turn off Valve A.
If Leak Sensor B detects a leak, turn off Valve B.
You can also have push notifications and texts sent, lights flash, or whatever else might be needed to get your attention (siren maybe?).
I considered doing a location specific set up but decided it was more work than its worth. If there’s water and I kill the main what’s the harm, no matter the location. The only place I would say it makes a difference is with a back up water powered sump pit.
