All of my motion sensors (Iris Motion Sensor IL07 3rd G) went offline at 12:30 am this morning. Nothing else is offline except for the motion sensors.
I was using the standard Smarthings Zigbee Motion Sensor edge driver. I cant change the driver because the devices are offline.
Hub has been restarted 2 times, and was disconnected for over 10 min.
Anyone else seeing this issue?
I have had 1 mine go offline several times, because it was sitting next my WiFi router. I have since moved it and solved the problem.
To fix remove battery, reinstall battery while holding reset button, and then do scan nearby. Don’t remove the device before rescanning. This will wake up the device without breaking any automations.
Thanks Paul, Ill do the battery reset a try when I get home.
The hub is far from the router, and the router has been there for almost 2 years with no issues on any other devices.
Still very odd that they all went offline at the same time but none of my other Zigbee devices had any problems.
