I just saw that Monoprice is now offering a zwave plus recessed door sensor that looks eerily similar to the aeon labs one, but with a better price of $29.99.
Seems to work well after repairing. It paired a zwave sensor and had to change dth to the Z-Wave Plus Door/Window Sensor dth.
This thing has a long sensing range, it seems to detect the magnet about an inch away. Battery reporting isnt working. Manual says to use battery get command class.
They are in the accessory pack, there are brown and white ones. Manual says you only have to use the wings if the hole is too wide. I havent installed it yet.
Thank you for the scan. It’s very well documented and should thus be easy to put together a dth (ie 10 min) unless there are firmware bugs. Will put one together if a I have chance this weekend. Won’t be able to test it since ST is only at the office, not at home.
Might be buggy and I can’t test. Anyway, try it. I’ll update it on Monday after I can actually test it. Will also implement setting of wake-up time interval.
Here’s the spec page with another version of the manual:
Another thought – if the default dth works and is local (not in the cloud), might be worth using that even if the battery level is not working
