Why can’t I use hub modes in the “if” part of automation and in “then” part of automation. What I want to do for example; is run an I’m back automation and change to home mode, but only if I’m not in Asleep mode. This is what I want to happen - if: TJ is present if: location mode (not check marking asleep) but checking others, then: run I’m back seen, then: change location mode to home.
ST has said that they are going to take a look at this restriction but as of right now, it’s just not possible.
Hey there! @TJK, at this time the option is not available.
I’ll be happy to tag your post as feed back to pass along to the developers for possible implementation in the future. Thanks for your loyalty!
