@Mavrrick58 Negative it is not showing any form of panel. I do however see all of the individual motion sensors and door sensors. This has been vexing me for days! Sorry for creating a new thread. Smartthings is only allowing me to reply 3 times due to me being a new member. Also, thank you for your help! I feel like I have wasted days of my life trying to figure this out.
You can edit your post. (Small pencil icon.) Would you mind to delete this and edit one of your previous posts. Thanks!
Well if the panel is not showing up under devices that is why you cant select it. You could try reseting the panel and reconfiguring eveything. You may want to reach out to smartthings support. It is the ADT Smartthings Panel you have right and not aome other ADT Alarm System right?
@Mavrrick58. It is an ADT Smartthings panel. I think doing a hard reset might be the best option. Thank you for your help. It is very gracious of you to carve out time to help me with this. @GSzabados I will delete this thread in the next 15 minutes. One question though, why would I go back and edit a response. I am not a website or IT guy, but this seems like a major impedance to effective communication for people answering questions. Either way this is your ship to captain, I will fall in and make the changes your requested.
Respectfully,
Andrew
In the IDE click on location across the top. Click on your current location. Once in the location scroll down until you find the section for hub. Click on that. Scroll down and tell me what your hardware version says.
Ok well it knows the hub is an ADT Alarm panel. I am not sure what to tell you at this point. You may want to reach out to Smartthings for support.
Do you have the ADT notification Smartapp loaded?
Yes Sir. I have it in my apps but have not put my phone number into this program yet.
If you’re missing the ADT Panel Device, that is concerning. I wouldn’t build things out any further until you resolve that. Resetting the panel would likely fix it or support might have a less painful way to fix it.
Thank you Brad. Prehaps a call to them is in order.
@Andrew_Anderson, the community forum has some rules to stop people spamming threads with continuous responses. You can edit your last post and can put an line like,
UPDATE: I am having problems still @Andrew_Anderson can you help me? It is easier to carry on in the same discussion than to open a new one for the same issue.
Hello @Brad_ST ,
Thank you for your response. I have submitted a ticket to smartthings. They are saying they can see the hub and it is not supposed to be listed under the device tab. Any ideas?
Hm, sounds as if they are confused about the hub versus the panel device. Are you able to clarify that you are able to see the Hub under the Hubs tab but that you are referring to the “Nortek Panel Device” from the Device tab?
