Here is the custom device handler I wrote. This shows up as Bahree Mimolite Switch. You can change the name to anything else (as long as it is unique) - this is in the first couple of lines where it says Definition name.
Once you have this published, then changed the switch type in the IDE to this, publish it, save it, and then it worked. Eventually I changed it back to the regular Z-Wave Switch in the type and it has been working fine. Hope this helps.
metadata {
// Automatically generated. Make future change here.
definition (name: "Bahree Mimolite Switch", namespace: "bahree", author: "Amit Bahree") {
capability "Configuration"
capability "Polling"
capability "Switch"
capability "Refresh"
capability "Contact Sensor"
attribute "powered", "string"
command "on"
command "off"
fingerprint deviceId: "0x1000", inClusters: "0x72,0x86,0x71,0x30,0x31,0x35,0x70,0x85,0x25,0x03"
simulator {
// Simulator stuff
// UI tile definitions
tiles {
standardTile("switch", "device.switch", width: 2, height: 2, canChangeIcon: true) {
state "doorClosed", label: "Closed", action: "on", icon: "st.doors.garage.garage-closed", backgroundColor: "#79b821"
state "doorOpen", label: "Open", action: "on", icon: "st.doors.garage.garage-open", backgroundColor: "#ffa81e"
state "doorOpening", label: "Opening", action: "on", icon: "st.doors.garage.garage-opening", backgroundColor: "#ffa81e"
state "doorClosing", label: "Closing", action: "on", icon: "st.doors.garage.garage-closing", backgroundColor: "#ffa81e"
state "on", label: "Actuate", action: "off", icon: "st.doors.garage.garage-closed", backgroundColor: "#53a7c0"
state "off", label: '${name}', action: "on", icon: "st.switches.switch.off", backgroundColor: "#ffffff"
standardTile("contact", "device.contact", inactiveLabel: false) {
state "open", label: '${name}', icon: "st.contact.contact.open", backgroundColor: "#ffa81e"
state "closed", label: '${name}', icon: "st.contact.contact.closed", backgroundColor: "#79b821"
standardTile("refresh", "device.switch", inactiveLabel: false, decoration: "flat") {
state "default", label:'', action:"refresh.refresh", icon:"st.secondary.refresh"
standardTile("powered", "device.powered", inactiveLabel: false) {
state "powerOn", label: "Power On", icon: "st.switches.switch.on", backgroundColor: "#79b821"
state "powerOff", label: "Power Off", icon: "st.switches.switch.off", backgroundColor: "#ffa81e"
standardTile("configure", "device.configure", inactiveLabel: false, decoration: "flat") {
state "configure", label:'', action:"configuration.configure", icon:"st.secondary.configure"
main (["switch", "contact"])
details(["switch", "powered", "refresh", "configure"])
log.debug "description is: ${description}"
def result = null
def cmd = zwave.parse(description, [0x20: 1, 0x84: 1, 0x30: 1, 0x70: 1])
log.debug "command value is: $cmd.CMD"
if (cmd.CMD == "7105") { //Mimo sent a power loss report
log.debug "Device lost power"
sendEvent(name: "powered", value: "powerOff", descriptionText: "$device.displayName lost power")
} else {
sendEvent(name: "powered", value: "powerOn", descriptionText: "$device.displayName regained power")
if (cmd) {
result = createEvent(zwaveEvent(cmd))
log.debug "Parse returned ${result?.descriptionText}"
return result
def sensorValueEvent(Short value) {
if (value) {
sendEvent(name: "contact", value: "open")
sendEvent(name: "switch", value: "doorOpen")
} else {
sendEvent(name: "contact", value: "closed")
sendEvent(name: "switch", value: "doorClosed")
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd) {
[name: "switch", value: cmd.value ? "on" : "off", type: "physical"]
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicSet cmd)
sensorValueEvent(cmd.value)
def zwaveEvent(physicalgraph.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd) {
def doorState = device.currentValue('contact')
if ( doorState == "closed")
[name: "switch", value: cmd.value ? "on" : "doorOpening", type: "digital"]
else
[name: "switch", value: cmd.value ? "on" : "doorClosing", type: "digital"]
def zwaveEvent(physicalgraph.zwave.commands.sensorbinaryv1.SensorBinaryReport cmd)
sensorValueEvent(cmd.sensorValue)
def zwaveEvent(physicalgraph.zwave.commands.alarmv1.AlarmReport cmd)
log.debug "We lost power" //we caught this up in the parse method. This method not used.
// Handles all Z-Wave commands we aren't interested in
def configure() {
log.debug "Configuring...." //setting up to monitor power alarm and actuator duration
delayBetween([
zwave.associationV1.associationSet(groupingIdentifier:3, nodeId:[zwaveHubNodeId]).format(),
zwave.configurationV1.configurationSet(configurationValue: [0], parameterNumber: 11, size: 1).format(),
zwave.configurationV1.configurationGet(parameterNumber: 11).format()
def on() {
delayBetween([
zwave.basicV1.basicSet(value: 0xFF).format(),
zwave.switchBinaryV1.switchBinaryGet().format()
def off() {
delayBetween([
zwave.basicV1.basicSet(value: 0x00).format(),
def poll() {
def refresh() {
