So that’s what the device looks like on the IDE, I went back to Association Group ID 1, but maybe even that is wrong, not sure. I wish I understood Z-Wave better and there weren’t so many differences between versions and manufacturers…
I tried with the above settings and I am getting a different behaviour now - it’s not something I can explain. With the above settings, button press 4 on and off gives:
9:21:42 PM: debug Parsed zw device: 6E, command: 600D, payload: 04 04 20 03 00 to MultiChannelCmdEncap(destinationEndPoint: 4, parameter: [0], sourceEndPoint: 4, command: 3, commandClass: 32, bitAddress: false) to null
9:21:42 PM: debug MultiChannelCmdEncap mapped - [name:switch4, value:off]
9:21:42 PM: debug MultiChannelCmdEncap called - MultiChannelCmdEncap(destinationEndPoint: 4, parameter: [0], sourceEndPoint: 4, command: 3, commandClass: 32, bitAddress: false)
9:21:42 PM: debug Event: zw device: 6E, command: 600D, payload: 04 04 20 03 00
9:21:42 PM: debug Parsed zw device: 6E, command: 600D, payload: 04 02 20 01 00 to MultiChannelCmdEncap(destinationEndPoint: 2, parameter: [0], sourceEndPoint: 4, command: 1, commandClass: 32, bitAddress: false) to null
9:21:42 PM: debug MultiChannelCmdEncap called - MultiChannelCmdEncap(destinationEndPoint: 2, parameter: [0], sourceEndPoint: 4, command: 1, commandClass: 32, bitAddress: false)
9:21:42 PM: debug Event: zw device: 6E, command: 600D, payload: 04 02 20 01 00
9:21:42 PM: debug Parsed zw device: 6E, command: 600D, payload: 04 03 20 01 00 to MultiChannelCmdEncap(destinationEndPoint: 3, parameter: [0], sourceEndPoint: 4, command: 1, commandClass: 32, bitAddress: false) to null
9:21:41 PM: debug MultiChannelCmdEncap mapped - [name:switch4, value:off]
9:21:41 PM: debug MultiChannelCmdEncap called - MultiChannelCmdEncap(destinationEndPoint: 3, parameter: [0], sourceEndPoint: 4, command: 1, commandClass: 32, bitAddress: false)
9:21:41 PM: debug Event: zw device: 6E, command: 600D, payload: 04 03 20 01 00
9:21:41 PM: debug Parsed zw device: 6E, command: 600D, payload: 04 01 20 01 00 to MultiChannelCmdEncap(destinationEndPoint: 1, parameter: [0], sourceEndPoint: 4, command: 1, commandClass: 32, bitAddress: false) to null
9:21:41 PM: debug MultiChannelCmdEncap called - MultiChannelCmdEncap(destinationEndPoint: 1, parameter: [0], sourceEndPoint: 4, command: 1, commandClass: 32, bitAddress: false)
9:21:41 PM: debug Event: zw device: 6E, command: 600D, payload: 04 01 20 01 00
9:21:38 PM: debug Parsed zw device: 6E, command: 600D, payload: 04 02 20 01 FF to MultiChannelCmdEncap(destinationEndPoint: 2, parameter: [255], sourceEndPoint: 4, command: 1, commandClass: 32, bitAddress: false) to null
9:21:38 PM: debug MultiChannelCmdEncap mapped - [name:switch4, value:on]
9:21:38 PM: debug MultiChannelCmdEncap called - MultiChannelCmdEncap(destinationEndPoint: 2, parameter: [255], sourceEndPoint: 4, command: 1, commandClass: 32, bitAddress: false)
9:21:38 PM: debug Event: zw device: 6E, command: 600D, payload: 04 02 20 01 FF
9:21:38 PM: debug Parsed zw device: 6E, command: 600D, payload: 04 01 20 01 FF to MultiChannelCmdEncap(destinationEndPoint: 1, parameter: [255], sourceEndPoint: 4, command: 1, commandClass: 32, bitAddress: false) to null
9:21:38 PM: debug MultiChannelCmdEncap called - MultiChannelCmdEncap(destinationEndPoint: 1, parameter: [255], sourceEndPoint: 4, command: 1, commandClass: 32, bitAddress: false)
9:21:38 PM: debug Event: zw device: 6E, command: 600D, payload: 04 01 20 01 FF
You can see SourceEndPoint is always 4 now. Moreover, it reflects on the app. To confirm this, I tried with button 3 as well:
9:25:08 PM: debug Parsed zw device: 6E, command: 600D, payload: 03 03 20 01 00 to MultiChannelCmdEncap(destinationEndPoint: 3, parameter: [0], sourceEndPoint: 3, command: 1, commandClass: 32, bitAddress: false) to null
9:25:08 PM: debug MultiChannelCmdEncap mapped - [name:switch3, value:off]
9:25:08 PM: debug MultiChannelCmdEncap called - MultiChannelCmdEncap(destinationEndPoint: 3, parameter: [0], sourceEndPoint: 3, command: 1, commandClass: 32, bitAddress: false)
9:25:08 PM: debug Event: zw device: 6E, command: 600D, payload: 03 03 20 01 00
9:25:08 PM: debug Parsed zw device: 6E, command: 600D, payload: 03 03 20 03 00 to MultiChannelCmdEncap(destinationEndPoint: 3, parameter: [0], sourceEndPoint: 3, command: 3, commandClass: 32, bitAddress: false) to null
9:25:08 PM: debug MultiChannelCmdEncap called - MultiChannelCmdEncap(destinationEndPoint: 3, parameter: [0], sourceEndPoint: 3, command: 3, commandClass: 32, bitAddress: false)
9:25:08 PM: debug Event: zw device: 6E, command: 600D, payload: 03 03 20 03 00
9:25:08 PM: debug Parsed zw device: 6E, command: 600D, payload: 03 02 20 01 00 to MultiChannelCmdEncap(destinationEndPoint: 2, parameter: [0], sourceEndPoint: 3, command: 1, commandClass: 32, bitAddress: false) to null
9:25:08 PM: debug MultiChannelCmdEncap called - MultiChannelCmdEncap(destinationEndPoint: 2, parameter: [0], sourceEndPoint: 3, command: 1, commandClass: 32, bitAddress: false)
9:25:08 PM: debug Event: zw device: 6E, command: 600D, payload: 03 02 20 01 00
9:25:08 PM: debug Parsed zw device: 6E, command: 600D, payload: 03 01 20 01 00 to MultiChannelCmdEncap(destinationEndPoint: 1, parameter: [0], sourceEndPoint: 3, command: 1, commandClass: 32, bitAddress: false) to null
9:25:08 PM: debug MultiChannelCmdEncap called - MultiChannelCmdEncap(destinationEndPoint: 1, parameter: [0], sourceEndPoint: 3, command: 1, commandClass: 32, bitAddress: false)
9:25:08 PM: debug Event: zw device: 6E, command: 600D, payload: 03 01 20 01 00
9:25:04 PM: debug Parsed zw device: 6E, command: 600D, payload: 03 03 20 03 FF to MultiChannelCmdEncap(destinationEndPoint: 3, parameter: [255], sourceEndPoint: 3, command: 3, commandClass: 32, bitAddress: false) to null
9:25:04 PM: debug MultiChannelCmdEncap mapped - [name:switch3, value:on]
9:25:04 PM: debug MultiChannelCmdEncap called - MultiChannelCmdEncap(destinationEndPoint: 3, parameter: [255], sourceEndPoint: 3, command: 3, commandClass: 32, bitAddress: false)
9:25:04 PM: debug Event: zw device: 6E, command: 600D, payload: 03 03 20 03 FF
9:25:04 PM: debug Parsed zw device: 6E, command: 600D, payload: 03 03 20 01 FF to MultiChannelCmdEncap(destinationEndPoint: 3, parameter: [255], sourceEndPoint: 3, command: 1, commandClass: 32, bitAddress: false) to null
9:25:04 PM: debug MultiChannelCmdEncap called - MultiChannelCmdEncap(destinationEndPoint: 3, parameter: [255], sourceEndPoint: 3, command: 1, commandClass: 32, bitAddress: false)
9:25:04 PM: debug Event: zw device: 6E, command: 600D, payload: 03 03 20 01 FF
9:25:04 PM: debug Parsed zw device: 6E, command: 600D, payload: 03 02 20 01 FF to MultiChannelCmdEncap(destinationEndPoint: 2, parameter: [255], sourceEndPoint: 3, command: 1, commandClass: 32, bitAddress: false) to null
9:25:04 PM: debug MultiChannelCmdEncap called - MultiChannelCmdEncap(destinationEndPoint: 2, parameter: [255], sourceEndPoint: 3, command: 1, commandClass: 32, bitAddress: false)
9:25:04 PM: debug Event: zw device: 6E, command: 600D, payload: 03 02 20 01 FF
And yes - the sourceEndPoint is always 3 now! And the app also reflects it.
Two considerable drawbacks though. Firstly, pressing button 1 did not reflect on the app:
9:27:11 PM: debug Parsed zw device: 6E, command: 600D, payload: 01 02 20 01 00 to MultiChannelCmdEncap(destinationEndPoint: 2, parameter: [0], sourceEndPoint: 1, command: 1, commandClass: 32, bitAddress: false) to null
9:27:11 PM: debug MultiChannelCmdEncap mapped - [name:switch1, value:off]
9:27:11 PM: debug MultiChannelCmdEncap called - MultiChannelCmdEncap(destinationEndPoint: 2, parameter: [0], sourceEndPoint: 1, command: 1, commandClass: 32, bitAddress: false)
9:27:11 PM: debug Event: zw device: 6E, command: 600D, payload: 01 02 20 01 00
9:27:11 PM: debug Parsed zw device: 6E, command: 600D, payload: 01 01 20 01 00 to MultiChannelCmdEncap(destinationEndPoint: 1, parameter: [0], sourceEndPoint: 1, command: 1, commandClass: 32, bitAddress: false) to null
9:27:11 PM: debug MultiChannelCmdEncap called - MultiChannelCmdEncap(destinationEndPoint: 1, parameter: [0], sourceEndPoint: 1, command: 1, commandClass: 32, bitAddress: false)
9:27:11 PM: debug Event: zw device: 6E, command: 600D, payload: 01 01 20 01 00
9:27:11 PM: debug Parsed zw device: 6E, command: 600D, payload: 01 03 20 01 00 to MultiChannelCmdEncap(destinationEndPoint: 3, parameter: [0], sourceEndPoint: 1, command: 1, commandClass: 32, bitAddress: false) to null
9:27:11 PM: debug MultiChannelCmdEncap called - MultiChannelCmdEncap(destinationEndPoint: 3, parameter: [0], sourceEndPoint: 1, command: 1, commandClass: 32, bitAddress: false)
9:27:11 PM: debug Event: zw device: 6E, command: 600D, payload: 01 03 20 01 00
9:27:11 PM: debug Parsed zw device: 6E, command: 600D, payload: 01 01 20 03 00 to MultiChannelCmdEncap(destinationEndPoint: 1, parameter: [0], sourceEndPoint: 1, command: 3, commandClass: 32, bitAddress: false) to null
9:27:11 PM: debug MultiChannelCmdEncap called - MultiChannelCmdEncap(destinationEndPoint: 1, parameter: [0], sourceEndPoint: 1, command: 3, commandClass: 32, bitAddress: false)
9:27:11 PM: debug Event: zw device: 6E, command: 600D, payload: 01 01 20 03 00
9:27:11 PM: debug Parsed zw device: 6E, command: 2003, payload: 00 to BasicReport(value: 0) to [‘name’:‘switch’, ‘value’:‘off’, ‘linkText’:‘Pool Area Sw. 2 Light 1’, ‘descriptionText’:Pool Area Sw. 2 Light 1 switch is off, ‘isStateChange’:true, ‘displayed’:true]
9:27:11 PM: debug BasicReport() called - BasicReport(value: 0)
9:27:11 PM: debug Event: zw device: 6E, command: 2003, payload: 00
9:26:54 PM: debug Parsed zw device: 6E, command: 2003, payload: FF to BasicReport(value: 255) to [‘name’:‘switch’, ‘value’:‘on’, ‘linkText’:‘Pool Area Sw. 2 Light 1’, ‘descriptionText’:Pool Area Sw. 2 Light 1 switch is on, ‘isStateChange’:false, ‘displayed’:false]
9:26:54 PM: debug BasicReport() called - BasicReport(value: 255)
9:26:54 PM: debug Event: zw device: 6E, command: 2003, payload: FF
9:26:54 PM: debug Parsed zw device: 6E, command: 600D, payload: 01 02 20 01 FF to MultiChannelCmdEncap(destinationEndPoint: 2, parameter: [255], sourceEndPoint: 1, command: 1, commandClass: 32, bitAddress: false) to null
9:26:54 PM: debug MultiChannelCmdEncap mapped - [name:switch1, value:on]
9:26:54 PM: debug MultiChannelCmdEncap called - MultiChannelCmdEncap(destinationEndPoint: 2, parameter: [255], sourceEndPoint: 1, command: 1, commandClass: 32, bitAddress: false)
9:26:54 PM: debug Event: zw device: 6E, command: 600D, payload: 01 02 20 01 FF
9:26:54 PM: debug Parsed zw device: 6E, command: 600D, payload: 01 04 20 01 FF to MultiChannelCmdEncap(destinationEndPoint: 4, parameter: [255], sourceEndPoint: 1, command: 1, commandClass: 32, bitAddress: false) to null
9:26:54 PM: debug MultiChannelCmdEncap called - MultiChannelCmdEncap(destinationEndPoint: 4, parameter: [255], sourceEndPoint: 1, command: 1, commandClass: 32, bitAddress: false)
9:26:54 PM: debug Event: zw device: 6E, command: 600D, payload: 01 04 20 01 FF
SourceEndPoint is correct even for button 1, but the app in this case did not budge. I notice the difference mainly is that button 1 sends a BasicReport, and to be honest, I just checked settings for these switches, the remaining ones I have on the old Zipato Controller have a setting that says “KEY 1 WILL NOT SEND BASIC REPORT”. That is likely a parameter that requires to be set.
Secondly, pressing the buttons in quick succession will lead to discrepancies between the app and physical reality. I am not sure why, perhaps the DTH cannot handle such quick key presses, or the hub, and it’s not like you can tell everyone to pause 1 second between button presses so the home automation system can handle it…
Anyhow, hope all this helps. It’s getting very late for me, perhaps tomorrow morning I will have some time to also run the scans and send them over. Many, many thanks for your assistance!
For sure - there is improvement and we can see the sourceEndPoint changing, and that seems like a huge step forward
