Iβve removed everything but my Z-wave devices from Smart Things hub. I am eagerly awaiting the first Matter-Zwave bridge. Not even HA is planning to support Bridging at first.
Zwave/Matter is much more difficult than zigbee, thread, or WiFi /Matter.
As you may know, the Matter project was originally called βProject ChIP.β The IP in chip stood for the IP addressing protocol. Zigbee, Thread, WiFi, and Bluetooth all already use that. Zwave standard does not. (There was an old zwave initiative, z/IP, that did, but no zwave hubs currently on the market do.)
SI Labs is planning to eventually create a platform (the Unify SDK) that hub manufacturers can use that will bridge Matter to zwave (via MQTT!) , but itβs still just in testing. And that will require a whole new zwave hub (not just a firmware update). Plus youβre going to see a lot of pretty diagrams showing matter/zwave via Unify, but they donβt detail the addressing issue, which is big for multiendpoint devices. Essentially the zwave controller is going to have to proxy an IP address for each endpoint. Itβs not impossible, but itβs not easy, and existing zwave hubs donβt do this today. ![]()
They havenβt said so, but my guess is we wonβt see that before zwave 800 is widely deployed. (Series 700 is just gaining traction now, and current SmartThings/Aeotec hubs use Series 600.) So likely at least 18 to 24 months, and thatβs if hub manufacturers pour a ton of resources into it.(there are technical reasons why this will be easier to do with series 800.)
Itβs the same reason why there are several zigbee to HomeKit bridges today (Philips Hue, Aqara, Ikea, Zemismart, lidl, Homee, and several more) and so far just one zwave to HomeKit bridge (ThinkA, which is only available in Europe, costs four times as much as an Aeotec hub, and doesnβt support locks).
https://www.z-wave.com/shop-z-wave-smart-home-products/thinka-z-wave
The only zwave hub manufacturer Iβve seen say they intend to work with Matter is the new zbox from Zooz, but itβs in their βsomeday weβd like toβ bucket, not an actual initiative.
So, yes, someday there will probably be a native way to get at least some zwave devices to work with Matter, but it will likely require a whole new hub and my personal guess is it wonβt happen before 2026.
Maybe somebody can come up with some kind of homebridge equivalent before then, weβll just have to see. But youβre going to see βMatter bridgeβ hubs with zigbee and the official Matter logo in a few months. Zwave will take a lot longer.
Were the Matter onboarding issues ever fixed? Iβm trying to onboard an Eve Motion sensor (updated to Matter) and also getting errors on the last step.
they told me that I had too many drivers installed (21). Hub resources are not enough to run the Matter device
oh boy. Iβm at 18 drivers and 92 devices.
Looks like at least some of the Eve matter devices are now working with SmartThings, with some hassle to get pairing completed
https://www.theverge.com/23513535/matter-smart-home-device-testing-eve-google-apple-samsung
Yes they are. Was pretty easy after I figured out Fire tablets running Fire OS 7 wonβt work.
But Eve Motion lux is stuck at 1.
I am getting very confused! I have an ST wifi hub ET-WV525 and it never gets mentioned along with the V2, V3, Aeotec hubs.
Will the ET-WV525 wifi hub get Matter and or Thread?
Matter, yes. Thread, no.
Thank you. I am becoming overwhelmed with trying to keep up all the changes going on.
Looks like tplink matter smart plugs with claimed SmartThings compatibility out of the box
Available from tp link website in USA .
Looks like this is matter over WIFI rather than thread.
NOT available in uk yet.
Iβve one on order! Wondering if the Smartthings WiFi hubs are already compatible with Matter given the latest firmware update. Once I test it Iβll let you guys know ![]()
According to the support site, 45.9 is the minimum firmware for Matter. But I assume they have a switch on the backend they need to enable for it to show in the app and allow you to add a Matter device
Also, Samsung Family Hub devices (like a refrigerator) and the newest Samsung TVs can serve as hubs for Zigbee and Matter devices as well as be a Thread Border router by adding the SmartThings Hub Dongle to the device.
bep@debian10:~$ st edge:drivers:installed
βββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
# Label Name Device Id
1 SmartThings Hub - FamilyHub SmartThings Hub 0a72d990-60f0-4e35-9838-a9363a357a30
2 SmartThings Hub SmartThings Hub 2ca01359-7f67-469e-9887-172e72b0423f
? Select a hub.
Iβve just got the matter enabled smart plug and can confirm that I was unable to add it using the Smartthings WiFi hub. As soon as the plug was connected to the mains it was detected automatically by Google Home and the Smartthings app, however when trying to pair it I got a βyour hub does not support this deviceβ message (attached). I was able to add it to Google Home and the Tapo Apps. The only way I found to control it thru Smartthings was by connecting it thru the cloud service. Hopefully Matter is soon enabled on the WiFi hubs
Same experience on the same hub and likely the same Tapo device
There does not appear to be Matter over Wi-Fi support in the ST Wi-Fi hub as of today. There has been no answer as to when or if support will be added.
I wonder what would happen if someone with a smartthings Wi-Fi mesh hub added the new Samsung smartthings station to their account?
its purpose is to act as a matter hub, and it supports both Wi-Fi and thread for matter.
I think Iβd be able to add the Smartthings Station and pair the wifi matter device to it. However, any automation that requires the usage of any of the sensors paired to the WiFi hub will be forced to be executed on the cloud, defeating the purpose of Matter local controlβ¦
True, but you would get the other matter benefits, in particular, having a wider selection of hopefully less expensive devices to choose from. So it might be attractive to some people and not others.
When Samsung team will look for hubs ST Home Connect and ST Wifi adding Matter? These are original Samsung devices, without descent attention and support.
