I just released a new module to display device statues on MagicMirror if anyone is interested.
My MagicMirror project is not using a mirror, just a standard display: https://forum.magicmirror.builders/topic/11153/new-non-mirror
I like that.
I might push myself to finish mine off now.
I did the basic setup but never got round to getting a display.
I followed your instructions and i see the header āSMARTTHINGSā but i get only āLoadingā below it. Any ideas why this could be happening?
What options are you using in the config? If you start MM using dev mode or open the dev console are there any errors?
Thanks for the reply.
For the config, i used your configuration, i replaced contactSensor and lock capabilities with temperatureMeasurement and motionSensor since i donāt have any locks. I obviously created a personal access token and added that to the config.
I wasnāt sure if the id had to be like this āā or like this āabcdefgā so i tried both. I restarted the raspberry pie just to be sure.
How can i I can check the dev console to see for any errors? I can do that once i get home.
Start MM in dev mode using:
npm start dev
Iāll test using those configs and see if I get any issues as well.
sounds good, iām online now so i can work on it. I will report back in a few
I just did a test using those and all of mine displayed fine in the module. Wondering if you have some special characters in your device names or anything like that?
If you have MM running via PM2, you can type the following to display the last few lines of the logs, but scrolling up youāll see the paths to the logs to view their full content:
pm2 logs MagicMirror
or if your name for the service is different:
pm2 log serviceNameHere
you can see the list of service names using:
pm2 list
ok i will try this first
0 info it worked if it ends with ok
1 verbose cli [ ā/usr/bin/nodeā, ā/usr/bin/npmā, āstartā ]
2 info using npm@6.9.0
3 info using node@v10.16.3
4 verbose run-script [ āprestartā, āstartā, āpoststartā ]
5 info lifecycle magicmirror@2.8.0~prestart: magicmirror@2.8.0
6 info lifecycle magicmirror@2.8.0~start: magicmirror@2.8.0
7 verbose lifecycle magicmirror@2.8.0~start: unsafe-perm in lifecycle true
8 verbose lifecycle magicmirror@2.8.0~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
9 verbose lifecycle magicmirror@2.8.0~start: CWD: /home/pi/MagicMirror
10 silly lifecycle magicmirror@2.8.0~start: Args: [ ā-cā, āsh run-start.shā ]
11 silly lifecycle magicmirror@2.8.0~start: Returned: code: 1 signal: null
12 info lifecycle magicmirror@2.8.0~start: Failed to exec start script
13 verbose stack Error: magicmirror@2.8.0 start: sh run-start.sh
13 verbose stack Exit status 1
13 verbose stack at EventEmitter. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:301:16)
13 verbose stack at EventEmitter.emit (events.js:198:13)
13 verbose stack at ChildProcess. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
13 verbose stack at ChildProcess.emit (events.js:198:13)
13 verbose stack at maybeClose (internal/child_process.js:982:16)
13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
14 verbose pkgid magicmirror@2.8.0
15 verbose cwd /home/pi/MagicMirror
16 verbose Linux 4.19.57-v7l+
17 verbose argv ā/usr/bin/nodeā ā/usr/bin/npmā āstartā
18 verbose node v10.16.3
19 verbose npm v6.9.0
20 error code ELIFECYCLE
21 error errno 1
22 error magicmirror@2.8.0 start: sh run-start.sh
22 error Exit status 1
23 error Failed at the magicmirror@2.8.0 start script.
23 error This is probably not a problem with npm. There is likely additional logging output above.
24 verbose exit [ 1, true ]
i see this when i start the magicmirror btw⦠i removed my samsung id
url: https://api.smartthings.com/v1/devices
method: GET
json: true
headers:
Authorization: Bearer mysamsungidabcde
qs:
capability: temperatureMeasurement
body:
Ok, Are running the start from an ssh window or on the pi itself. If itās via ssh, that error would be because it canāt find electron in ssh, youād need to run the npm start dev on the piās terminal.
You can change the ipwhitelist and address to allow connections from a regular web browser on another pc.
It looks like itās getting the device info from your last post.
Are there any other messages like that or just that one?
messages like the one from the magicmirror when it starts? Yes, one for motionSensor and one for temperatureMeasurement. It seems that it is repeating a few times.
Iām working through VNC right now because i just broke the mini hdmi adaptor. Iām getting a new one in about an hour and i can run npm start dev once i hook up the monitor again.
What should i report back once i start in dev mode?
There should be one for each device after each of those, so seems to be getting hung up looping those. All of my devices were under a Component called āmainā, which I assumed was standard, but maybe itās not. Let me do some checking on that.
If youāre willing to do some testing, you can send a request for the device information using a rest client in chrome. The request information is in the screenshot, just pass your key using the Authorization header in a GET request. It isnāt obvious in that , but you can scroll down in the frame wehre the green bar is to see the json results. Under one of the deviceās, look for Components and see if itās called āmainā.
I use an extension in chrome that lets me test rest connections call Rest Client: https://chrome.google.com/webstore/detail/restlet-client-rest-api-t/aejoelaoggembcahagimdiliamlcdmfm
Also have you tried just one capability at a time to narrow down if itās related to connection or capability?
unless i did something wrong, i got a [401 Unauthorized]
yes i tried with one capability
Ah, so 401. Maybe generate a new samsung key and try it?
Just tried it⦠same thing 401.
Does it matter that i am in EU?
