Lost Hub configuration, reseted to factory default!
For a bit more detail on this… There was a bug (it’s probably existed for a while and just surfaced) where the platform would return no locations (generally when under stress). We put in limits server-side to mitigate the vast majority of possibilities where this could occur (also - as a separate workflow - the recent database work helped alleviate the stress). We will also be adding updates to the next mobile builds as a secondary prevention measure.
IF you come across an unexpected getting started screen again, force quit and reopen the app. Also shoot a note to support@ with the approximate time it occurred so we can investigate.
