I can use the GD00Z-4 to OPEN the garage door using SmartThings. The garage door shows correctly as OPEN.
When I send commands to it, I can see SmartThings is sending them but nothing happens even after 10-15 minutes. I have to use the garage door opener I have in my car to close the garage again. The garage door opener on the wall will not work either.
RBoy
2
Bring your hub closer and try it out (you may have to repair it). If that fixes the issue add a z-wave repeater between your device and the hub.
I had a similar problem. Moving the hub, or plug in another z-wave device to act as a repeater really helped the reliability of the garage controller. Another thing I did was shorten the wire that connects from the gd00z to the garage opener. For some reason the extra length cause reliability problems for me.
