Linear Garage Door Opener Stopped Working
That is correct. If you did not replace the LED, no light.
I fixed two units by replacing the LED. The LED of one of my repairs worked for a couple years, then it failed with same problem. So, this time (today) I put a 3.3 ohm 3W resistor in instead of new LED and it is back up and running. Resistors should last a lot longer than LED. The other repair with the LED is still going strong, but I suspect that LED will eventually fail as well, at which time I’ll go the resistor fix route with it too. Thanks again @timnord!
