I did my first self-install of a Leviton Decora z-Wave Switch today and looking for some help. I thought it was going to be as straightforward as adding in a neutral wire but i’ve run into a problem. The problem however is not with the Leviton switch, it’s the older (dumb) switch on the other end of the 3-way.
The Leviton switch is working fine, turns the lights on/off, allows me to turn on/off from my phone. The older 3way switch which i have not touched won’t turn the lights off when they are on, and won’t turn them on when they are off.
Any ideas? Have i wired the Leviton incorrectly and that is the issue?
I think the issue is you cannot do what you’re trying to do. I don’t use the Leviton switches b I’m pretty sure you have to change the other switch too to a slave similar to how he does it. I’m sure others will chime in soon but I’d check into that first.
