Please let me know if this isn’t the correct place to post this type of question - I’m still trying to find my way around here.
I’m trying to create the SmartApp “Keep Me Cozy II” and use it with my nest thermostat and the Everspring ST814 remote temperature sensor. If I pick any temperature sensor (Aeon, Everspring, or smartthings) I get this error. So I guess it is the nest thermostat that is causing this problem?? I’m just using an iPhone and the SmartThings app to create the smartapp.
Since the app won’t even save it seems that I’m not even getting as far as others in the community seem to have so just wondering where to start. I do have the new firmware if that may be a possibility. I believe that I have the latest nest device type code but given the variety of places and threads with this I just can’t be completely sure.
Thanks for responding. I was just able to create a Pollster smartapp but it looks like there was just a new version posted (1.2). It looks like pollster isn’t even listed in the shared community, convenience apps now so I pasted in the code directly from Github. Reason I mentioned it is that I was actually able to create a new smartapp, but that one is probably different then the regular ones in some key way, I’ll bet.
I saw reference to the 500 error but I didn’t see that in the iPhone app anywhere. Is there someplace I should be looking closer in the iPhone app in the future for more details?
I think I’ve figured out the source of the problem. Line 85 has a log trace that tries to output all the current settings. I narrowed the error down to when it tries to log the value for currentHeatingSetpoint. I think this errors on SOME systems because some systems are in Cool only mode so there isn’t a value for heatsetpoint in that mode.
If you want to play around with fixing it, you can make a new SmartApp using the developer IDE and base it on the Cozy II template. Then you can comment out line 85 and everything should work.
