IKEA Vindstyrka air quality sensor successfully paired
Tagging @constantgraph since the problem is the values not appearing there.
Hi @Per_Viberg could you send me a PM or email to contact@constantgraph.com with the email address you used to sign up to ConstantGraph with and I’ll take a look at your account and see if I can move you forwards. Thanks!
Ikea Vindstyrka air quality sensor works with my ST v2 hub no issues. When I use the ST integration with Home Assistant the device data set is missing the PM2.5 information. Does anyone know of a fix for the missing PM2.5 data on HA?
Thanks, Richard
Scroll down to the troubleshooting section on this page, activate the log and see if HA receives the data.
There’s nothing I can do on the driver’s side.
The HA debug log reports the following:
2025-08-27 09:31:42.967 DEBUG (MainThread) [pysmartthings] Received event: {“eventTime”:1756305102904,“eventType”:“DEVICE_EVENT”,“deviceEvent”:{“eventId”:“8d434bab-8352-11f0-952b-0d582173ea29”,“locationId”:“”, “ownerId”:“”,“ownerType”:“LOCATION”, “deviceId”:“3b37e553-aaad-4c54-9284-4445f51f28a3”, “componentId”:“main”, “capability”:“fineDustSensor”,“attribute”:“fineDustLevel”,“value”:3,“valueType”:“number”,“unit”:“μg/m^3”,“stateChange”:true,“data”:{},“subscriptionName”:“My Home Assistant sub”,“commandId”:“”,“sensitive”:false}}
I appears that the data is getting through.
Then everything is fine. Thanks for the feedback.
Posted the issue on the Discord HA/ST Integrations: Discord
