Hi guys. I bought the Air Quality Sensor Z-Wave Plus Eurotronic the other day. Unfortunately there is no suitable driver for it. I tried to write my own. But, unfortunately, I can not achieve an indication of air quality by VOC and dew point. The air indication should be interpreted in terms of the VOC value. The meaning itself is shown in the appendix, only the interpretation is not visible. Please, help. Don’t swear too much, I’m not a programmer. The driver is written by an amateur, so to speak.
metadata {
definition(name: “Luftgütesensor”, namespace: “Aelfot”, author: “aelfot”, mnmn: “SmartThingsCommunity”, vid: “generic-leak-5”, ocfDeviceType: “x.com.st.d.airqualitysensor”) {
capability “Dew Point”
capability “Carbon Dioxide Measurement”
capability “Tvoc Measurement”
capability “Temperature Measurement”
capability “Relative Humidity Measurement”
capability “Sensor”
capability “Configuration”
capability “Tvoc Health Concern”
capability “Carbon Dioxide Health Concern”fingerprint mfr:"0148", prod:"0005", model:"0001" fingerprint mfr:"0000", prod:"0000", model:"0000" }tiles(scale: 2) {
multiAttributeTile(name: “water”, type: “generic”, width: 6, height: 6) {
tileAttribute(“device.water”, key: “PRIMARY_CONTROL”) {
attributeState(“dry”, label:‘${name}’, icon: “st.alarm.water.dry”, backgroundColor: “#ffffff”)
attributeState(“wet”, label:‘${name}’, icon: “st.alarm.water.wet”, backgroundColor: “#00A0DC”)
valueTile(“humidity”, “device.humidity”, inactiveLabel: false, width: 2, height: 2) {
state “humidity”, label: ‘${currentValue}%’, unit: “”
valueTile(“temperature”, “device.temperature”, width: 2, height: 2) {
state(“temperature”, label: ‘${currentValue}°’,
backgroundColors: [
// Celsius
[value: 0, color: “#153591”],
[value: 7, color: “#1e9cbb”],
[value: 15, color: “#90d2a7”],
[value: 23, color: “#44b621”],
[value: 28, color: “#f1d801”],
[value: 35, color: “#d04e00”],
[value: 37, color: “#bc2323”],
// Fahrenheit
[value: 40, color: “#153591”],
[value: 44, color: “#1e9cbb”],
[value: 59, color: “#90d2a7”],
[value: 74, color: “#44b621”],
[value: 84, color: “#f1d801”],
[value: 95, color: “#d04e00”],
[value: 96, color: “#bc2323”]
valueTile(“carbonDioxide”, “device.co2Level”, inactiveLabel: false, width: 2, height: 2) {
state “carbonDioxide”, label: ‘${currentValue}’, unit: “”
valueTile(“dewPoint”, “device.dewPoint”, inactiveLabel: false, width: 2, height: 2) {
state “dewPoint”, label:‘${currentValue}°’, unit: “”
valueTile(“tvocLevel”, “device.tvocLevel”, inactiveLabel: false, width: 2, height: 2) {
state “tvocLevel”, label: ‘${currentValue}’, unit: “”
standardTile(“carbonDioxideHealthConcern”, “device.carbonDioxideHealthConcern”, inactiveLabel: false, width: 2, height: 2) {
state “good”, label:‘Hohe Raumluftqualität’, unit: “”
state “moderate”, label:‘Mittlere Raumluftqualität’, unit: “”
state “slightlyUnhealthy”, label:‘Mäßige Raumluftqualität’, unit: “”
state “unhealthy”, label:‘Niedrige Raumluftqualität’, unit: “”
state “veryUnhealthy”, label:‘Raumluftqualität unakzeptabel’, unit: “”
standardTile(“tvocHealthConcern”, “device.tvocHealthConcern”, inactiveLabel: false, width: 2, height: 2) {
state “good”, label:‘Luft frei von Verunreinigungen’, unit: “”
state “moderate”, label:‘Luft frei von Verunreinigungen’, unit: “”
state “slightlyUnhealthy”, label:‘Geringfügige Verunreinigung’, unit: “”
state “unhealthy”, label:‘Mittelmäßige Verunreinigung’, unit: “”
}preferences { input "Temperaturdifferenz", "enum", title: "Temperaturdifferenz", options: ["0.1", "0.5", "1"], description: "Report, wenn Temperature geändert 0.1...5,0°C", defaultValue: "0.5" , displayDuringSetup: true input "Feuchtigkeitsdifferenz", "number", title: "Feuchtigkeitsdifferenz", description: "Report, wenn Feuchtigkeit geändert 1...100%", defaultValue: 5, range: "1..100", displayDuringSetup: false input "Temperatureeinheit", "enum", title: "Temperatureeinheit", options: ["°C", "°F"], defaultValue: "°C", required: false, displayDuringSetup: true input "TemperaturAufloesung", "enum", title: "Auflösung Temperatur", options: ["keine Nachkommastelle", "eine Nachkommastelle", "zwei Nachkommastellen"], defaultValue: "eine Nachkommastelle", required: false, displayDuringSetup: true input "FeuchtigkeitsAufloesung", "enum", title: "Auflösung Feuchte", options: ["keine Nachkommastelle", "eine Nachkommastelle", "zwei Nachkommastellen"], defaultValue: "keine Nachkommastelle", required: false, displayDuringSetup: true input "VOCChageReporting", "number", title: "VOC-on Change Reporting", description: "VOC-on Change Reporting 100...1000 ppb", range: "100..1000", displayDuringSetup: false input "CO2ChangeReporting", "number", title: "CO2 Change Reporting", description: "CO2 Change Reporting 100...1000 ppb", range: "100..1000", displayDuringSetup: false input "LedIndikation", "enum", title: "Luftgüte per LED signalisieren", options: ["nein", "ja"], defaultValue: "ja", required: false, displayDuringSetup: true } main "water" details(["water", "humidity", "temperature", "carbonDioxide", "dewPoint", "tvocLevel", "carbonDioxideHealthConcern", "tvocHealthConcern"])}
}def installed() {
sendEvent(name: “dewPoint”, value: 0, unit: “C”, linkText:“$device.displayName”, descriptionText: “$device.displayName Dew Point is $value”, isStateChange:true, displayed:true)
sendEvent(name: “carbonDioxideHealthConcern”, value: “good”, linkText:“$device.displayName”, descriptionText: “$device.displayName Hohe Raumluftqualität”, isStateChange:true, displayed:true)
sendEvent(name: “tvocHealthConcern”, value: “good”, linkText:“$device.displayName”, descriptionText: “$device.displayName Sauber”, isStateChange:true, displayed:true)
response([
secure(zwave.notificationV3.notificationGet(notificationType: 0x0D)), // Home Health
“delay 500”,
secure(zwave.sensorMultilevelV5.sensorMultilevelGet(sensorType: 0x01)), // temperature
“delay 500”,
secure(zwave.sensorMultilevelV5.sensorMultilevelGet(sensorType: 0x05)), // humidity
“delay 500”,
secure(zwave.sensorMultilevelV5.sensorMultilevelGet(sensorType: 0x0B)), // dewpoint
“delay 500”,
secure(zwave.sensorMultilevelV5.sensorMultilevelGet(sensorType: 0x11)), // CO2
“delay 500”,
secure(zwave.sensorMultilevelV5.sensorMultilevelGet(sensorType: 0x27)), // VOC
“delay 10000”,
secure(zwave.wakeUpV2.wakeUpNoMoreInformation())
}def updated() {
configure()
}def configure() {
sendEvent(name: “dewPoint”, value: 13, unit: “°”, linkText:‘$device.displayName’, descriptionText: “$device.displayName Dew Point is $value”, isStateChange:true, displayed:true)
sendEvent(name: “carbonDioxideHealthConcern”, value: “good”, linkText:‘$device.displayName’, descriptionText: “$device.displayName Hohe Raumluftqualität”, isStateChange:true, displayed:true)
sendEvent(name: “tvocHealthConcern”, value: “good”, linkText:‘$device.displayName’, descriptionText: “$device.displayName Sauber”, isStateChange:true, displayed:true)
sendEvent(name: “checkInterval”, value: 8 * 60 * 60 + 10 * 60, displayed: false, data: [protocol: “zwave”, hubHardwareId: device.hub.hardwareID])
secure(zwave.configurationV1.configurationSet(configurationValue: Temperaturdifferenz == “0.1” ? [0x01] : Temperaturdifferenz == “0.5” ? [0x05] : [0x0A] , parameterNumber:1, size:1, scaledConfigurationValue: Temperaturdifferenz == “0.1” ? 0x01 : Temperaturdifferenz == “0.5” ? 0x05 : 0x0A))//,
secure(zwave.configurationV1.configurationSet(configurationValue: Feuchtigkeitsdifferenz == null ? [0x05] : [Integer.toHexString(Feuchtigkeitsdifferenz).toUpperCase()], parameterNumber:2, size:1, scaledConfigurationValue: Feuchtigkeitsdifferenz == null ? 0x05 : Integer.toHexString(Feuchtigkeitsdifferenz).toUpperCase()))//,
secure(zwave.configurationV1.configurationSet(configurationValue: Temperatureeinheit == “°C” ? [0x00] : [0x01], parameterNumber:3, size:1, scaledConfigurationValue: Temperatureeinheit == “°C” ? 0x00 : 0x01))//,
secure(zwave.configurationV1.configurationSet(configurationValue: TemperaturAufloesung == “keine Nachkommastelle” ? [0x00] : TemperaturAufloesung == “eine Nachkommastelle” ? [0x01] : [0x02], parameterNumber:4, size:1, scaledConfigurationValue: TemperaturAufloesung == “keine Nachkommastelle” ? 0x00 : TemperaturAufloesung == “eine Nachkommastelle” ? 0x01 : 0x02))//,
secure(zwave.configurationV1.configurationSet(configurationValue: FeuchtigkeitsAufloesung == “keine Nachkommastelle” ? [0x00] : FeuchtigkeitsAufloesung == “eine Nachkommastelle” ? [0x01] : [0x02], parameterNumber:5, size:1, scaledConfigurationValue: FeuchtigkeitsAufloesung == “keine Nachkommastelle” ? 0x00 : FeuchtigkeitsAufloesung == “eine Nachkommastelle” ? 0x01 : 0x02))//,
secure(zwave.configurationV1.configurationSet(configurationValue: VOCChageReporting == null ? [0x05] : [Integer.toHexString(VOCChageReporting-100).toUpperCase()], parameterNumber:6, size:1, scaledConfigurationValue: VOCChageReporting == null ? 0x05 : VOCChageReporting-100))//,
secure(zwave.configurationV1.configurationSet(configurationValue: CO2ChangeReporting == null ? [0x05] : [Integer.toHexString(CO2ChangeReporting-100).toUpperCase()], parameterNumber:7, size:1, scaledConfigurationValue: CO2ChangeReporting == null ? 0x05 : CO2ChangeReporting-100))//,
secure(zwave.configurationV1.configurationSet(configurationValue: LedIndikation == “nein” ? [0x00] : [0x01], parameterNumber:8, size:1, scaledConfigurationValue: LedIndikation == “nein” ? 0x00 : 0x01))//,
}def parse(String description) {
def results =
if (description.startsWith(“Err”)) {
results += createEvent(descriptionText: description, displayed: true)
} else {
def cmd = zwave.parse(description)
if (cmd) {
results += zwaveEvent(cmd)
log.debug “parse() result ${results.inspect()}”
return results
}def zwaveEvent(physicalgraph.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) {
def encapsulatedCommand = cmd.encapsulatedCommand()
if (encapsulatedCommand) {
zwaveEvent(encapsulatedCommand)
} else {
log.warn “Unable to extract encapsulated cmd from $cmd”
createEvent(descriptionText: cmd.toString())
}def zwaveEvent(physicalgraph.zwave.commands.notificationv3.EventSupportedReport cmd) {
switch (cmd.event) {
case 1:
createEvent(name:“tvocHealthConcern”, value:“good”, linkText:‘$device.displayName’, descriptionText:“$device.displayName Zielwert”, isStateChange:true, displayed:true)
sendPush(“Luftqualität ist super”)
break;
case 2:
createEvent(name:“tvocHealthConcern”, value:“moderate”, linkText:‘$device.displayName’, descriptionText:“$device.displayName Verstärktes Lüften wird empfohlen”, isStateChange:true, displayed:true)
sendPush(“Luftqualität ist nicht perfekt. Lüften empfohlen”)
break;
case 3:
createEvent(name:“tvocHealthConcern”, value:“slightlyUnhealthy”, linkText:‘$device.displayName’, descriptionText:“$device.displayName Verstärktes Lüften notwendig”, isStateChange:true, displayed:true)
sendPush(“Luftqualität ist schlecht. Verstärktes Lüften notwendig”)
break;
case 4:
createEvent(name:“tvocHealthConcern”, value:“unhealthy”, linkText:‘$device.displayName’, descriptionText:“$device.displayName Nur nutzen, wenn unvermeidbar”, isStateChange:true, displayed:true)
sendPush(“Luftqualität ist miserabel. Raum nutzen nur, wenn unvermeidbar. Lüften!!!”)
break;
case 5:
createEvent(name:“tvocHealthConcern”, value:“veryUnhealthy”, linkText:‘$device.displayName’, descriptionText:“$device.displayName Nur nutzen, wenn unvermeidbar”, isStateChange:true, displayed:true)
sendPush(“Luftqualität ist lebensgefährlich. Raum verlassen und lüften.”)
break;
}def zwaveEvent(physicalgraph.zwave.commands.notificationv3.NotificationReport cmd) {
case 1:
break;
case 2:
break;
case 3:
break;
case 4:
break;
case 5:
break;
}def zwaveEvent(physicalgraph.zwave.commands.sensormultilevelv5.SensorMultilevelReport cmd) {
def map = [:]
switch (cmd.sensorType) {
case 1:
map.name = “temperature”
map.unit = temperatureScale
map.value = convertTemperatureIfNeeded(cmd.scaledSensorValue, cmd.scale == 1 ? “F” : “C”, cmd.precision)
break;
case 5:
map.name = “humidity”
map.unit = cmd.scale == 0 ? “%” : “g/m^3”
map.value = cmd.scaledSensorValue.toFloat()
break;
case 0xB:
map.name = “dewPoint”
map.unit = cmd.scale == 1 ? “F” : “C”
map.isStateChange = true
map.displayed = true
break;
case 0x11:
map.name = “carbonDioxide”
map.unit = cmd.scale == 0 ? “Parts/million” : “”
map.value = cmd.scaledSensorValue.toInteger()
sensorcarbonDioxideHealthConcernLevel (map.value)
break;
case 0x27:
map.name = “tvocLevel”
map.unit = cmd.scale == 1 ? “Parts/million” : “mol/m^3”
sensortvocHealthConcernLevel (map.value)
break;
default:
map.descriptionText = cmd.toString()
createEvent(map)
}def zwaveEvent(physicalgraph.zwave.commands.wakeupv2.WakeUpNotification cmd) {
def cmds =
def result = createEvent(descriptionText: “$device.displayName woke up”, isStateChange: false)
cmds += secure(physicalgraph.zwave.commands.notificationv3.NotificationGet(notificationType: 0x0D))
cmds += secure(zwave.sensorMultilevelV5.sensorMultilevelGet(sensorType: 0x27))
cmds += secure(zwave.sensorMultilevelV5.sensorMultilevelGet(sensorType: 0x11))
cmds += secure(zwave.sensorMultilevelV5.sensorMultilevelGet(sensorType: 0x0B))
cmds += secure(zwave.sensorMultilevelV5.sensorMultilevelGet(sensorType: 0x05))
cmds += secure(zwave.sensorMultilevelV5.sensorMultilevelGet(sensorType: 0x01))
cmds += secure(zwave.wakeUpV2.wakeUpNoMoreInformation())
[result, response(cmds)]
}def zwaveEvent(physicalgraph.zwave.Command cmd) {
log.warn “Unhandled command: ${cmd}”
}def sensortvocHealthConcernLevel (value) {
if (value < 0.065) {
sensortvocHealthConcern (1)
} else if (value < 0.22) {
sensortvocHealthConcern (2)
} else if (value < 0.66) {
sensortvocHealthConcern (3)
} else if (value < 2.2) {
sensortvocHealthConcern (4)
} else {
sensortvocHealthConcern (5)}
}def sensorcarbonDioxideHealthConcernLevel (value) {
if (value < 800) {
sensorcarbonDioxideHealthConcern (1)
} else if (value < 1000) {
sensorcarbonDioxideHealthConcern (2)
} else if (value < 1400) {
sensorcarbonDioxideHealthConcern (3)
} else if (value < 2000) {
sensorcarbonDioxideHealthConcern (4)
} else {
sensorcarbonDioxideHealthConcern (5)}
}def sensorcarbonDioxideHealthConcern (value) {
switch (value) {
case 1:
sendEvent(name:“carbonDioxideHealthConcernn”, value:“good”, linkText:‘$device.displayName’, descriptionText:“$device.displayName Zielwert”, isStateChange:true, displayed:true)
break;
case 2:
sendEvent(name:“carbonDioxideHealthConcernn”, value:“moderate”, linkText:‘$device.displayName’, descriptionText:“$device.displayName Verstärktes Lüften wird empfohlen”, isStateChange:true, displayed:true)
break;
case 3:
sendEvent(name:“carbonDioxideHealthConcernn”, value:“slightlyUnhealthy”, linkText:‘$device.displayName’, descriptionText:“$device.displayName Verstärktes Lüften notwendig”, isStateChange:true, displayed:true)
break;
case 4:
sendEvent(name:“carbonDioxideHealthConcernn”, value:“unhealthy”, linkText:‘$device.displayName’, descriptionText:“$device.displayName Nur nutzen, wenn unvermeidbar”, isStateChange:true, displayed:true)
break;
case 5:
sendEvent(nname:“carbonDioxideHealthConcernn”, value:“veryUnhealthy”, linkText:‘$device.displayName’, descriptionText:“$device.displayName Nur nutzen, wenn unvermeidbar”, isStateChange:true, displayed:true)
break;
}def sensortvocHealthConcern (value){
switch (value) {
case 1:
sendEvent(name:“tvocHealthConcern”, value:“good”, linkText:‘$device.displayName’, descriptionText:“$device.displayName Zielwert”, isStateChange:true, displayed:true)
break;
case 2:
sendEvent(name:“tvocHealthConcern”, value:“moderate”, linkText:‘$device.displayName’, descriptionText:“$device.displayName Verstärktes Lüften wird empfohlen”, isStateChange:true, displayed:true)
break;
case 3:
sendEvent(name:“tvocHealthConcern”, value:“slightlyUnhealthy”, linkText:‘$device.displayName’, descriptionText:“$device.displayName Verstärktes Lüften notwendig”, isStateChange:true, displayed:true)
break;
case 4:
sendEvent(name:“tvocHealthConcern”, value:“unhealthy”, linkText:‘$device.displayName’, descriptionText:“$device.displayName Nur nutzen, wenn unvermeidbar”, isStateChange:true, displayed:true)
break;
case 5:
sendEvent(name:“tvocHealthConcern”, value:“veryUnhealthy”, linkText:‘$device.displayName’, descriptionText:“$device.displayName Nur nutzen, wenn unvermeidbar”, isStateChange:true, displayed:true)
break;
}private secure(cmd) {
if (zwaveInfo.zw.contains(“s”)) {
zwave.securityV1.securityMessageEncapsulation().encapsulate(cmd).format()
} else {
cmd.format()
