Purchased today.
Resetted device, connected as Zigbee Humidity Sensor (SmartThings driver for Zigbee humidity sensor devices).
Have you found any driver to read air quality data?
I have a version 2 hub but canāt get it to pair. I press the link āresetā button 4x and the link icon blinks but smartthings does not see it.
Is there something i am doing wrong?
Iām having issues in general adding to my v2 hub.
I have a driver in development to support the VINDSTYRKA sensor. It uses the pm2.5 value as reported to calculate the CAQI (0-100) and the AQI (good, moderate, unhealthy, etc) capabilities. It is also reporting temp and humidity.
I plan on adding an attribute to display the actual pm2.5 value once I get more time.
Iāll have it for release on my channel soon.
Edit:
If you came here to find a driver for this device: here it is:
(Accept, Enroll, Available Drivers, ā¦)
That would be awesome! And what about the tVOC value?
And is it possible to turn the display back light off?
It doesnāt appear that the tVOC value is actually sent via Zigbee. It appears that internally it may only be calculating a relative tVOC value over time and on the small display only shows if its staying the same, rising or falling (the little arrow). There are several custom clusters that iāve not fully explored yet though.
My backlight turns off after X minutes automatically. I doubt its controllable via Zigbee however.
Just ordered one a minute ago.
Going to examine the clusters when it arrives next week.
On pairing, it reports:
Manufacturer: IKEA of Sweden Model: VINDSTYRKA
[1]: server: Basic, Identify, Groups, TemperatureMeasurement, RelativeHumidity, 0xFC57, 0xFC7C, 0x042A, 0xFC7E |
client: Identify, OTAUpgrade, PollControl, FanControl [242]: server | client: 0x0021
temperature, humidity, pm25, voc_index, identify, linkquality
Yeah, pm2.5 is on cluster 0x0042, and voc_index (0-500) is on cluster 0xfc7e. I have voc_index implemented in code but donāt have a custom attribute for it yet either. And its odd since it cant be queried, it only sends it on a schedule.
Correct.
Zigpy has these clusters:
INPUT_CLUSTERS: [
Basic.cluster_id, # 0x0000
Identify.cluster_id, # 0x0003
Groups.cluster_id, # 0x0004
TemperatureMeasurement.cluster_id, # 0x0402
RelativeHumidity.cluster_id, # 0x0405
PM25.cluster_id, # 0x042a
WWAH_CLUSTER_ID, # 0xfc57
IKEA_CLUSTER_ID, # 0xfc7c
VOCIndex.cluster_id, # 0xfc7e
OUTPUT_CLUSTERS: [
Ota.cluster_id, # 0x0019
PollControl.cluster_id, # 0x0020
Fan.cluster_id, # 0x0202
Hereās an explanation for the VOC index:
If you donāt find the time for a release, could you upload the code as it is to GitHub?
Iāve not had a chance to clean it up yet, thereās an issue I was trying to debug where the device isnāt handling the reporting correctly and ends up flooding the network with reports every second.
ā¦as an alternative:
For those of you living in Europe: there is an affordable zigbee air quality sensor from āfrientā, which works great within smartthings.
They also offer a dedicated edge driver for their device and you can use all the readings in routines as well.
This is not a sponsored post of course, i am just very happy with the brand and their devices.
But it only measures VOC and not PM2.5.
I already have the IKEA device and if I had a little more time, Iād write an edge driver for it. But that wouldnāt make sense since @csstup driver seems to be almost finished.
Itās perfectly integrated in HA by the way.
Almost thereā¦
At this pace Iāll finish the driver by Christmas⦠![]()
Last night I did something with my proof of concept driver and now the device is sending its data as it should. It stopped flooding the network and is sending pm2.5 at the correct interval.
Now I have to find out what I did at 3 am in the morningā¦
aroedl@hydra ~/devel $ grep INFO /home/aroedl/logcat1
2024-11-15T09:50:45.491294903Z INFO Zigbee Humidity Sensor AR Doing health check read for [39D9]:0405:0000
2024-11-15T09:50:45.493108153Z INFO Zigbee Humidity Sensor AR <ZigbeeDevice: 8ddc0647-ecf7-4755-bd1c-5fcc42945503 [0x39D9] (Multipurpose Sensor Test)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x39D9, dest_endpoint: 0x01, profile: 0x0104, cluster: RelativeHumidity >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2024-11-15T09:50:45.513374153Z INFO Zigbee Humidity Sensor AR Doing health check read for [39D9]:042A:0000
2024-11-15T09:50:45.518048528Z INFO Zigbee Humidity Sensor AR <ZigbeeDevice: 8ddc0647-ecf7-4755-bd1c-5fcc42945503 [0x39D9] (Multipurpose Sensor Test)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x39D9, dest_endpoint: 0x01, profile: 0x0104, cluster: 0x042A >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2024-11-15T09:50:45.631097153Z INFO Zigbee Humidity Sensor AR <ZigbeeDevice: 8ddc0647-ecf7-4755-bd1c-5fcc42945503 [0x39D9] (Multipurpose Sensor Test)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x39D9, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: RelativeHumidity >, lqi: 0xD0, rssi: -66, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x19, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Uint16, MeasuredValue: 0x125C > > > >
2024-11-15T09:50:45.654809153Z INFO Zigbee Humidity Sensor AR Executing ZclClusterAttributeValueHandler: cluster: RelativeHumidity, attribute: MeasuredValue
2024-11-15T09:50:45.658038819Z INFO Zigbee Humidity Sensor AR <ZigbeeDevice: 8ddc0647-ecf7-4755-bd1c-5fcc42945503 [0x39D9] (Multipurpose Sensor Test)> emitting event: {"attribute_id":"humidity","capability_id":"relativeHumidityMeasurement","component_id":"main","state":{"value":47}}
2024-11-15T09:50:45.685041444Z INFO Zigbee Humidity Sensor AR <ZigbeeDevice: 8ddc0647-ecf7-4755-bd1c-5fcc42945503 [0x39D9] (Multipurpose Sensor Test)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x39D9, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0x042A >, lqi: 0xC4, rssi: -66, body_length: 0x000B, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x1A, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: SinglePrecisionFloat, SinglePrecisionFloat: (1 + 0.726562) * 2^(7) > > > >
2024-11-15T09:50:45.702691819Z INFO Zigbee Humidity Sensor AR Executing ZclClusterAttributeValueHandler: cluster: 0x042A, attribute: 0x0000
2024-11-15T09:50:45.705524903Z INFO Zigbee Humidity Sensor AR <ZigbeeDevice: 8ddc0647-ecf7-4755-bd1c-5fcc42945503 [0x39D9] (Multipurpose Sensor Test)> emitting event: {"attribute_id":"fineDustLevel","capability_id":"fineDustSensor","component_id":"main","state":{"value":221}}
2024-11-15T09:51:45.521810201Z INFO Zigbee Humidity Sensor AR Doing health check read for [39D9]:0402:0000
2024-11-15T09:51:45.523784701Z INFO Zigbee Humidity Sensor AR <ZigbeeDevice: 8ddc0647-ecf7-4755-bd1c-5fcc42945503 [0x39D9] (Multipurpose Sensor Test)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x39D9, dest_endpoint: 0x01, profile: 0x0104, cluster: TemperatureMeasurement >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2024-11-15T09:51:45.634939576Z INFO Zigbee Humidity Sensor AR <ZigbeeDevice: 8ddc0647-ecf7-4755-bd1c-5fcc42945503 [0x39D9] (Multipurpose Sensor Test)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x39D9, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: TemperatureMeasurement >, lqi: 0xCE, rssi: -64, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x1C, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Int16, MeasuredValue: 2300 > > > >
2024-11-15T09:51:45.649055035Z INFO Zigbee Humidity Sensor AR Executing ZclClusterAttributeValueHandler: cluster: TemperatureMeasurement, attribute: MeasuredValue
2024-11-15T09:51:45.653127868Z INFO Zigbee Humidity Sensor AR <ZigbeeDevice: 8ddc0647-ecf7-4755-bd1c-5fcc42945503 [0x39D9] (Multipurpose Sensor Test)> emitting event: {"attribute_id":"temperature","capability_id":"temperatureMeasurement","component_id":"main","state":{"unit":"C","value":23.0}}
2024-11-15T09:54:15.580011128Z INFO Zigbee Humidity Sensor AR Doing health check read for [39D9]:0405:0000
2024-11-15T09:54:15.581919211Z INFO Zigbee Humidity Sensor AR <ZigbeeDevice: 8ddc0647-ecf7-4755-bd1c-5fcc42945503 [0x39D9] (Multipurpose Sensor Test)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x39D9, dest_endpoint: 0x01, profile: 0x0104, cluster: RelativeHumidity >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2024-11-15T09:54:15.609572878Z INFO Zigbee Humidity Sensor AR Doing health check read for [39D9]:042A:0000
2024-11-15T09:54:15.617755919Z INFO Zigbee Humidity Sensor AR <ZigbeeDevice: 8ddc0647-ecf7-4755-bd1c-5fcc42945503 [0x39D9] (Multipurpose Sensor Test)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x39D9, dest_endpoint: 0x01, profile: 0x0104, cluster: 0x042A >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2024-11-15T09:54:15.759378461Z INFO Zigbee Humidity Sensor AR <ZigbeeDevice: 8ddc0647-ecf7-4755-bd1c-5fcc42945503 [0x39D9] (Multipurpose Sensor Test)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x39D9, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: RelativeHumidity >, lqi: 0xCE, rssi: -66, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x1D, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Uint16, MeasuredValue: 0x12C0 > > > >
2024-11-15T09:54:15.772700503Z INFO Zigbee Humidity Sensor AR Executing ZclClusterAttributeValueHandler: cluster: RelativeHumidity, attribute: MeasuredValue
2024-11-15T09:54:15.776916503Z INFO Zigbee Humidity Sensor AR <ZigbeeDevice: 8ddc0647-ecf7-4755-bd1c-5fcc42945503 [0x39D9] (Multipurpose Sensor Test)> emitting event: {"attribute_id":"humidity","capability_id":"relativeHumidityMeasurement","component_id":"main","state":{"value":48}}
2024-11-15T09:54:15.802688045Z INFO Zigbee Humidity Sensor AR <ZigbeeDevice: 8ddc0647-ecf7-4755-bd1c-5fcc42945503 [0x39D9] (Multipurpose Sensor Test)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x39D9, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0x042A >, lqi: 0xCC, rssi: -66, body_length: 0x000B, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x1E, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: SinglePrecisionFloat, SinglePrecisionFloat: (1 + 0.691406) * 2^(9) > > > >
2024-11-15T09:54:15.816413461Z INFO Zigbee Humidity Sensor AR Executing ZclClusterAttributeValueHandler: cluster: 0x042A, attribute: 0x0000
2024-11-15T09:54:15.819402878Z INFO Zigbee Humidity Sensor AR <ZigbeeDevice: 8ddc0647-ecf7-4755-bd1c-5fcc42945503 [0x39D9] (Multipurpose Sensor Test)> emitting event: {"attribute_id":"fineDustLevel","capability_id":"fineDustSensor","component_id":"main","state":{"value":866}}
2024-11-15T09:55:15.596755218Z INFO Zigbee Humidity Sensor AR Doing health check read for [39D9]:0402:0000
2024-11-15T09:55:15.601519635Z INFO Zigbee Humidity Sensor AR <ZigbeeDevice: 8ddc0647-ecf7-4755-bd1c-5fcc42945503 [0x39D9] (Multipurpose Sensor Test)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x39D9, dest_endpoint: 0x01, profile: 0x0104, cluster: TemperatureMeasurement >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2024-11-15T09:55:15.734435218Z INFO Zigbee Humidity Sensor AR <ZigbeeDevice: 8ddc0647-ecf7-4755-bd1c-5fcc42945503 [0x39D9] (Multipurpose Sensor Test)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x39D9, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: TemperatureMeasurement >, lqi: 0xC6, rssi: -64, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x20, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Int16, MeasuredValue: 2300 > > > >
2024-11-15T09:55:15.748890302Z INFO Zigbee Humidity Sensor AR Executing ZclClusterAttributeValueHandler: cluster: TemperatureMeasurement, attribute: MeasuredValue
2024-11-15T09:55:15.750743968Z INFO Zigbee Humidity Sensor AR <ZigbeeDevice: 8ddc0647-ecf7-4755-bd1c-5fcc42945503 [0x39D9] (Multipurpose Sensor Test)> emitting event: {"attribute_id":"temperature","capability_id":"temperatureMeasurement","component_id":"main","state":{"unit":"C","value":23.0}}
2024-11-15T09:57:45.661993088Z INFO Zigbee Humidity Sensor AR Doing health check read for [39D9]:0405:0000
2024-11-15T09:57:45.666899874Z INFO Zigbee Humidity Sensor AR <ZigbeeDevice: 8ddc0647-ecf7-4755-bd1c-5fcc42945503 [0x39D9] (Multipurpose Sensor Test)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x39D9, dest_endpoint: 0x01, profile: 0x0104, cluster: RelativeHumidity >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2024-11-15T09:57:45.691109347Z INFO Zigbee Humidity Sensor AR Doing health check read for [39D9]:042A:0000
2024-11-15T09:57:45.692676089Z INFO Zigbee Humidity Sensor AR <ZigbeeDevice: 8ddc0647-ecf7-4755-bd1c-5fcc42945503 [0x39D9] (Multipurpose Sensor Test)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x39D9, dest_endpoint: 0x01, profile: 0x0104, cluster: 0x042A >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2024-11-15T09:57:45.824516559Z INFO Zigbee Humidity Sensor AR <ZigbeeDevice: 8ddc0647-ecf7-4755-bd1c-5fcc42945503 [0x39D9] (Multipurpose Sensor Test)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x39D9, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0x042A >, lqi: 0xCC, rssi: -65, body_length: 0x000B, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x22, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: SinglePrecisionFloat, SinglePrecisionFloat: (1 + 0.375000) * 2^(8) > > > >
2024-11-15T09:57:45.837123485Z INFO Zigbee Humidity Sensor AR Executing ZclClusterAttributeValueHandler: cluster: 0x042A, attribute: 0x0000
2024-11-15T09:57:45.847504256Z INFO Zigbee Humidity Sensor AR <ZigbeeDevice: 8ddc0647-ecf7-4755-bd1c-5fcc42945503 [0x39D9] (Multipurpose Sensor Test)> emitting event: {"attribute_id":"fineDustLevel","capability_id":"fineDustSensor","component_id":"main","state":{"value":352}}
2024-11-15T09:57:45.875584080Z INFO Zigbee Humidity Sensor AR <ZigbeeDevice: 8ddc0647-ecf7-4755-bd1c-5fcc42945503 [0x39D9] (Multipurpose Sensor Test)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x39D9, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: RelativeHumidity >, lqi: 0xC0, rssi: -65, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x21, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Uint16, MeasuredValue: 0x11F8 > > > >
2024-11-15T09:57:45.886742490Z INFO Zigbee Humidity Sensor AR Executing ZclClusterAttributeValueHandler: cluster: RelativeHumidity, attribute: MeasuredValue
2024-11-15T09:57:45.888564025Z INFO Zigbee Humidity Sensor AR <ZigbeeDevice: 8ddc0647-ecf7-4755-bd1c-5fcc42945503 [0x39D9] (Multipurpose Sensor Test)> emitting event: {"attribute_id":"humidity","capability_id":"relativeHumidityMeasurement","component_id":"main","state":{"value":46}}
2024-11-15T09:58:45.681364146Z INFO Zigbee Humidity Sensor AR Doing health check read for [39D9]:0402:0000
2024-11-15T09:58:45.683132146Z INFO Zigbee Humidity Sensor AR <ZigbeeDevice: 8ddc0647-ecf7-4755-bd1c-5fcc42945503 [0x39D9] (Multipurpose Sensor Test)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x39D9, dest_endpoint: 0x01, profile: 0x0104, cluster: TemperatureMeasurement >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2024-11-15T09:58:45.814640855Z INFO Zigbee Humidity Sensor AR <ZigbeeDevice: 8ddc0647-ecf7-4755-bd1c-5fcc42945503 [0x39D9] (Multipurpose Sensor Test)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x39D9, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: TemperatureMeasurement >, lqi: 0xCC, rssi: -64, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x23, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Int16, MeasuredValue: 2300 > > > >
2024-11-15T09:58:45.828738146Z INFO Zigbee Humidity Sensor AR Executing ZclClusterAttributeValueHandler: cluster: TemperatureMeasurement, attribute: MeasuredValue
2024-11-15T09:58:45.832946063Z INFO Zigbee Humidity Sensor AR <ZigbeeDevice: 8ddc0647-ecf7-4755-bd1c-5fcc42945503 [0x39D9] (Multipurpose Sensor Test)> emitting event: {"attribute_id":"temperature","capability_id":"temperatureMeasurement","component_id":"main","state":{"unit":"C","value":23.0}}
What I see in the logs:
The device is not sending any configured spontaneous reports (reportAttribute command).
Since device is not sending reports, the healt_check function is being activated and it is sequentially reading the monitored attributes and the device is responding with the reportAttributeResponse command.
This attribute monitoring function will disappear for stock drivers in the new firmware version 55.x, or so they have announced.
EDIT:
@Andreas_Roedl
Rereading the clarification about attribute monitoring in firmware version 55.x post, the correct interpretation is that the default attribute monitoring is not removed by default and what they are going to do is remove it in the stock drivers and make it optional to disable it for other non-stock drivers, in order to improve some memory and latency.
language comprehension problems!
I have tested the new firmware 55.2 and indeed if you do not disable monitoring of the device attributes with the device:remove_monitored_attribute(cluster_id, attribute_id) function, after device configuration, they will continue to be monitored as before.
Thanks, mate!
Even for mains-powered devices?
I have no idea, in their announcement they did not distinguish between types of devices.
They have not released the beta version either, which should have been released between November 13th and 14th to be able to verify how it really works.
