I bought a few ikea trådlös leds to integrate with my smartthings hub v3 (without the ikea hub) . All worked flawlessly except for the 1000 lumen lamp with white spectrum control. This one can be dimmed and tone controlled manually from the smartthings app, but when put in a scene or automation the dimmer value is either ignored or even randomly set (most often to really low values: 10-ish %). Not sure what’s wrong! Anyone else had the same issue?
I would try resetting the bulb and joining it again to see if that helps. Did you verify in ide that the correct dth was assigned upon it joining the network?
So then i interpret it as being a problem with ST rather than a malfunctioning led. Could there be something wrong with the standard DH for this model of led? I am not familiar enough with DH syntax to be able to tell…
