IKEA blinds have stopped updating (March 2025)
Hi,
My IKEA blinds stopped updating after actions (at least I haven’t detected any other devices with problems).
For example, if I open the blind, I have to go to the device and manually refresh it so that the current status or position can be updated.
Tried with two different zigbee window treatment drivers (smartthings (version 24/02/2025) and mariano (version 23/02/2025)) but without success.
I have also restarted the router and ST hub but with no success.
V3_HUB
firmware: 000.055.00005
You could write an auto refresh rule in the Rules API and set it up to automatically refresh every X minutes. See the following link.
Hi @Paul_Oliver
Thanks for your suggestion, I’ll save it in case I need it in the future.
In any case the situation was resolved after removing the battery, wait a couple of hours and replacing it.
Thank you!
I have found this occasionally after hub reboots or Zigbee mesh updates. Putting the blind into discovery mode (long press both buttons on the blind) and then add device/scan nearby in ST brings them back with no loss of routines ect ect.
Is effectively the same thing…
