IFTTT not seeing WeMo notification
Anyone else seen this? Not really a smartthings issue I don’t think but odd.
I have a smartthings trigger if) to a wemo light switch (then). If I have one switch selected as part of the “then” rule I get the notification that the recipe was triggered and ran. If I set it to all wemo switches (which is an option) I do not get a notification and the routine says it never fired (but it did and all lights turned off or on per the rule).
Net, net, a “then” wemo rule where you select “all switches” works but no record of the rule firing or notification occurs.
I think that is a bug.
It sounds like a WeMo channel bug. I would report it to WeMo support.
