When I try to use the SmartThings service in IFTTT and select the device that’s an Iris contact sensor for the open/close event IFTTT recognizes it and I can use it to trigger events fine. However if I use the SmartThings service with IFTTT and select temperature sensor SmartThings isn’t reporting the Iris contact sensor out as a temperature sensor.
In the SmartThings mobile app I can see the open/close status, temperature, and battery level of the Iris contact sensor. Is this a problem with SmartThings not reporting out the temperature to external integrations or am I in the wrong spot and need to be looking at IFTTT as the problem?
