Ide issues this morning
I’ve seen it cause crash… cause the page to be blanked out and also as I described above change to not get committed even though save shows no errors, if you go back in your changes are not there.
not sure why it works different ways different times. It probably has to do with what capabilities or tiles or on the device or some combination.
I didn’t say it was an excuse for incompetence and negligence. What I am saying is incompetent, negligent people use agile as an excuse for why they are not designing, documenting, testing etc.
@Lgkahn I have also noticed that once the code gets “locked up” as in when you return your changes are missing, you are screwed. The only solution seems to be to rename the device so you can start over. You usually need to contact support to delete the old version because it gets jacked up.
nice feature… no need to do any support if you cannot change anything… maybe add that to all device types :smile:
